Home > Maintenance & Mods (L322) > Windscreen replacement |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2926 |
My front screen has a couple of chips in it and yesterday, I found that only the passenger side is clearing when the heat is switched on.
16th Nov 2010 4:55pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
are the RR screens made by pilkington V8 facelift Range Rover Autobiography 22" wheels.
16th Nov 2010 5:26pm |
Where's the difference? Just had my screen replaced recently - the only difference i found was that there is about 8mm gap between the L and R side heating elements - so you have a thin vertical frost line directly in the middle of the windshield. Can live with that to now.
16th Nov 2010 6:39pm |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
That gap exists on my 2010
16th Nov 2010 7:16pm |
Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313 |
Had that gap on every car I've had with the heated screen. Keeps the two banks of heating elements seperate as the current runs up one side and down the other doesn't it?
16th Nov 2010 7:44pm |
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 |
I had a mare getting a heated screen for my Classic years back, but I did eventually get it sorted.
16th Nov 2010 8:02pm |
InVogue Member Since: 03 Nov 2010 Location: Cheshire Posts: 57 |
Well, would you believe it! After replying to this thread in the afternoon, I got a nasty chip in the windscreen thiis evening - as it is large and in the drivers field of vision it will have to be replaced!
16th Nov 2010 8:13pm |
How do I delete my reply 2010 Disco XS TDV6, 2009 Freelander 2 GS Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy". |
16th Nov 2010 8:15pm |
Maybe it's best if you avoid the motorways tonight |
16th Nov 2010 8:33pm |
andyw Member Since: 15 Oct 2009 Location: united kingdom Posts: 160 |
must be the climate i had a stone chip fixed last week after a BMW assist 5 series went past doing a rate of nots flicked a stone and bang one times chip. had it fixed by auto glass ery good job with the resin, also had the windscreen change by them last year noticed absolutey no diference apart from it loked a lot newere (funny old thing) 02 Range Rover HSE Zambezie silver 4.4 |
16th Nov 2010 10:27pm |
I've not had the gap on any of my RR's. The L&R are completely separate circuits and technically, the current will only be running in one direction - either up or down depending on the polarity. I had Carglass do the work here in France because I agreed to having them do the work when I insured my car. Anyone else and my premium is higher. I have no idea if Carglass and Autoglass are related, but I can tell you that the work that he did on the windshield itself was impeccable. No 3 tons of mastic and if there is a leak it will be a freak accident. After watching him work - and admiring his specialist tools - I can guarantee that no dealer would have installed my windshield better (the actual glass, that is). Quite likely, they, the unpracticed dealer monkeys, would have done a worse job on the glass. He did break 2 clips on the new A-pillar covers and re-installed all the plastic rivets w/o the center pins... Didn't watch closely when he finished up and now have to have him come out again sometime. I'd prefer to have the actual glass work done well, tho. No leaks or other major problems. The clips I can sort myself if need be. RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
16th Nov 2010 10:47pm |
Pauld Member Since: 15 Mar 2010 Location: Sheffield Posts: 199 |
I think most dealers use specialist glass repairers as opposed to their own staff.
16th Nov 2010 11:33pm |
Had my Discovery glass changed - Dealership don't do it themselves.
16th Nov 2010 11:53pm |
They don't do much these day! More facilitators than getting hands dirty. 2010 Disco XS TDV6, 2009 Freelander 2 GS
17th Nov 2010 1:41am |
