Home > Maintenance & Mods (L322) > Windscreen replacement |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3057 |
one on ebay for £370 + postage
17th Nov 2010 10:31am |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2926 |
If thats the case, I wonder if its something else thats failed. Left side clears fine, but the right side doesn't. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
19th Nov 2010 4:34pm |
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 |
When I was with LR insurance and needed the windscreen checking (chip was just filled by Autoglass in the end anyway) they said that they were rolling out a system whereby all the LR main dealers would handle the windscreen replacement , but I think this basically entails Autoglass etc going to the LR dealer to do the work on your car and I assume the mechanics there check the rear view mirror/rain sensor is functioning correctly (and I think the air bags come into it aswell). I asked Autoglass about windscreen replacement and they said they would use either LR or Pilkingtons. As I'm not too impressed with my original windscreen, I will probably try Pilkingtons if it ever needs changing , but if they are one and the same, then I'm out of luck! Steve
21st Nov 2010 2:42am |
