Home > Off Topic - Other Cars > Led running lights |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3955 |
28th Aug 2013 4:30pm |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 |
Vogue MY 2010 is the same - they are side lights and come on only with the switch. New model has them as daylight running lights.
28th Aug 2013 5:08pm |
Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608 |
On a 2010MY L322 onwards they can be switched on as DRL's with a faultmate
28th Aug 2013 9:05pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16180 |
Are you sure the Faultmate switches the LED's on as DRL's as the IID tool switches on the main beam at 40% strength or the headlamps only... No option for LED's |
28th Aug 2013 9:13pm |
Certainly does on mine
28th Aug 2013 9:23pm |
Interesting... Thank you Andy |
28th Aug 2013 9:32pm |
As above, though you can turn on the the Scandinavian or Canadian DRL option as well with the Faultmate FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
28th Aug 2013 9:53pm |
Rich86 Member Since: 10 Mar 2013 Location: Surrey Posts: 509 |
Well according to that link the disco forum say they work in place of side lights although mine seems to have side lights and not drls...most cars have options to turn these on and off via settings I thought. 2009 Vogue TDV8 Nara Bronze
29th Aug 2013 1:24am |
gvw Member Since: 30 Apr 2012 Location: South Yorkshire Posts: 10 |
Are you sure the LEDs are physically there as some of the lower models do not have them and have the standard sidelight |
29th Aug 2013 6:49am |
Not sure they are there but the headlights have the pattern. So maybe this is a con! 2009 Vogue TDV8 Nara Bronze
2nd Sep 2013 6:13pm |
All Disco 4 headlamps look the same but only top model cars have the LED's... Does your car have side light bulbs? If so the LED's are dummys. If you turn on your side lights and the LED's come on then "voila" |
3rd Sep 2013 1:20am |
RangeK1D Member Since: 21 May 2013 Location: Calgary, Alberta Posts: 163 |
Hey Ajay, which faultmate model are you using? I went on to the BlackBox solutions website but there are a bazillion products. Zambezi Silver Range Rover (2010 Autobiography Facelift)
31st Dec 2015 8:33pm |
Faultmate MSV-2 Extreme with SM136 RR 2010+ Multi-Vehicle Licence
5th Jan 2016 10:44am |
Lad Member Since: 12 Oct 2014 Location: Blackburn Posts: 284 |
The iid tool can switch on the led lights to come on ON their own when the ignition is switched on. |
6th Jan 2016 11:00pm |
