Home > Technical (L322) > Battery blues |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6666 |
Might be better off with a 110A jobby - http://www.eurocarparts.com/ecp/c/Land+Rov...amp;000020 Got - 2017 SDV8 Autobiography in Loire Blue
24th Jan 2016 10:17pm |
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 416 |
Check for parasitic drains and the alternator is healthy. An over charging alternator can wreck a battery. |
25th Jan 2016 1:17am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
If you don't use it a lot suggest you get a decent trickle charger (e.g. Ctek) so you can keep the battery in tip top condition. .
25th Jan 2016 1:19am |
Ian c2 Member Since: 19 May 2015 Location: Socal Posts: 217 |
^^. Agreed ^^
25th Jan 2016 2:09am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16176 |
Check the output from the alternator first... If all good and no other drains on the car? I personally would shell out the extra for a Gen Battery sir,,,
25th Jan 2016 11:21am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3954 |
^ It does seem to be the case but my Bosch S5 110AH from Eurocarparts has survived 5 years without problems.
25th Jan 2016 11:43am |
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 |
https://www.tayna.co.uk/EA1000-Exide-Premi...P7488.html (also "D2BOYS" discount code). Best value around IMO. Visiting from DISCO3.CO.UK
25th Jan 2016 12:13pm |
^ Only 100AH though Got - 2017 SDV8 Autobiography in Loire Blue
25th Jan 2016 12:24pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3680 |
What capacity is the heavy duty supplied by main dealers? And how long do they guarantee it for?
25th Jan 2016 12:34pm |
NDFI... I do understand where your coming from but! And it's a big but... 20+ customers/forum members came to me with Bosch S5 batteries and most have been changed once or twice under warranty by ECP and more than half of those customers have opted to change the battery type afterwards.
25th Jan 2016 12:58pm |
Perfectly adequate though. The only way to really improve things with a battery is to look after it, since the cars aren't actually much good at keeping them well charged themselves. Visiting from DISCO3.CO.UK Discovery 3 TDV6 Auto HSE Zambezi Silver |
25th Jan 2016 12:59pm |
As above. Also worth whiping it out before the cold hits and doing a full regen on it if you have a trickle charger style device that can do it
25th Jan 2016 2:26pm |
Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267 |
It is pretty much proven that if you use your FF little or left for a week or two you are going to end up with a flat one.Somewhere there is a slight drain or other slight problem particularly an older model and you are going to struggle without a trickle charger.Batteries like being used every day ,that is fact. |
25th Jan 2016 8:04pm |
Interesting though you hear lots of complaints about the Bosch but not about the Varta. Maybe that is @ expectations?
25th Jan 2016 10:02pm |
