Home > Wheels & Tyres > New profile tyres V's suspension fault |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3196 |
"I then have to park up for 30 mins. Let's the compressor cool down. "
7th Feb 2016 1:11pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34933 |
to fit the new tyres , the FF would have had to be jacked up possibly revealing a hole in the bag as John has suggested..
7th Feb 2016 1:16pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7636 |
So the side walls will be about 151mm instead of about 127mm so the car should be about an inch higher from the floor as it sits normally. I can't see how that would change things compressor wise as the height is taken in relation from the body to the wheel, not the ground...... Unless someone tells me otherwise....
7th Feb 2016 2:26pm |
MikeT Member Since: 19 May 2014 Location: Moscow Posts: 87 |
Cheers guys. Useful info as always. Right then. Where do I find these airbags?
7th Feb 2016 2:42pm |
did you suspect they were leaking ?
7th Feb 2016 2:45pm |
Prevention is better than cure ))
7th Feb 2016 2:51pm |
Agreed - the last thing you want is frozen airbags.
7th Feb 2016 2:55pm |
Ok great. I'll check the airbags. Could the larger tyres have caused a puncture in the bags?
7th Feb 2016 3:02pm |
You'll have to see if the bigger tyres rubbed on the bags, though a few on here have put oversize tyres on without issue. Not done it myself so not an expert.
7th Feb 2016 3:08pm |
Hi Mike, what is the age of your car ?? The bags do fail at some point, on my SC in Nigeria (US model imported) the fronts failed after 6 years. The cracks in both bags were completely covered in the fold and only when the suspension bushings were replaced and I asked them to check, the cracks became visible. The front struts were removed and the bags were blown up a lot. Lots of longitudinal cracks in both, no small little pinhole for sure !!!! We could hear the leaks (the car was having issues before so I knew there was some leak.
7th Feb 2016 3:11pm |
All 4 corners dropped. It's a 2006 SC btw |
7th Feb 2016 3:17pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7916 |
My tyres are taller than yours and are nowhere near the airbags, they would hit and rub in lots of other places first before they got to the bags... Pete
7th Feb 2016 3:37pm |
