Home > Maintenance & Mods (L322) > Terraclean and ReMap |
Steveo Member Since: 26 Jan 2015 Location: Essex Posts: 156 |
I have one on my td6 and it is really good it's been on about 2years with no issues |
18th Feb 2016 3:57pm |
Pvw10 Member Since: 04 Nov 2015 Location: Ledbury Posts: 314 |
My remap at a proper place not chappy with a laptop was £150 which was cheap for sure, based in Gloucester Many thanks
18th Feb 2016 5:05pm |
Cavalier Member Since: 04 Sep 2015 Location: Bletchley Posts: 189 |
Thanks for the replies. Steveo, do you know how they did it, downloaded a file via the port, or did they have to open the ecu and fit a chip, or adjust the ecu setting. The reason I question the cost is, the last 2 Landrovers I had remapped, a Discovery 3 and a Discovery 4, cost me in the region of £500 each.
18th Feb 2016 6:40pm |
Ha ha of course done with a lap top I meant rather than jack the lad who turns up with one.
18th Feb 2016 6:45pm |
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 |
As regards a "proper place" vs "laptop chappy", bear in mind, most tuners have mobile dealers and all that's required to load the map is a laptop while the file is written by the tuner at their place, so don't assume it has any bearing on the quality of the map. Equally, even a place with a full dyno can do a shoddy job.
18th Feb 2016 6:47pm |
I meant the type who turn up in there own car and do the job not the pro guys.
18th Feb 2016 6:52pm |
It was done by the obd port they down load your current map send it of to the tuners who then send over a improved map that they install they keep your original map on file in case you want it returned to standard |
18th Feb 2016 6:58pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1698 |
Be interested in your thoughts on the Terraclean. I had one done a few months ago. Waste of time and money, I felt |
18th Feb 2016 7:02pm |
Hi Mikey, followed your posts over on the Disco forum over the years. The reason I am having a Teraclean is to (in my mind) start from a clean slate. My December 2011 4.4 has only got 30k on the clock, and I am doing a lot of short stop start journeys, probably total 5-6k per year. I had the DPF full light come on last week, took it for 200mile round trip up the motorway, when it finished regenerating I had quite a bad miss fire and the car seemed to loose its low down performance.
18th Feb 2016 7:47pm |
