Home > Technical (L322) > Error Codes |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1698 |
Ignore them then |
19th Feb 2016 8:22am |
Realist Member Since: 13 Feb 2016 Location: Wales Posts: 436 |
Thank you your a star |
19th Feb 2016 11:32am |
Done just this tonight and the screen said 12.0v idle and when running its showing 13.5v.
20th Feb 2016 12:43am |
What Craig said, the alternator is doing something, however I would also now check with a volt meter across the battery terminals at idle and confirm the 12v. If it is only 12v then the alternator is dying. It should put out 13.5v minimum at idle, rising to 14.5 when it is charging after starting.
21st Feb 2016 11:27am |
Tested with my multimeter tonight and at standing between the + and - it reads 12.0v and starting up, running lights, heaters everything to get the alternator to kick in and it reads 13.5v max.
21st Feb 2016 11:02pm |
Now who lives in South Wales and is handy at changing Alternators? |
21st Feb 2016 11:04pm |
Found a mechanic that can supply and fit the alternator for ฃ435.00 is that cheap or expensive? |
22nd Feb 2016 5:20pm |
lighthouse Member Since: 22 Feb 2016 Location: Great Notley Posts: 513 |
sounds on the expensive side, what motor you got? |
22nd Feb 2016 6:03pm |
FFRR TDV8. |
22nd Feb 2016 6:09pm |
no idea where it is on the diesel so can't advise on the effort required would have thought part would be around ฃ200 mark |
22nd Feb 2016 6:35pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7929 |
Very much doubt you would get a decent alternator for one of them for ฃ200...
23rd Feb 2016 4:52pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34946 |
you can get a decent deal for these alternators Pete
23rd Feb 2016 5:11pm |
Blimey they have come down a bit in price... nearly as cheap as the earlier ones now.... Pete
23rd Feb 2016 5:14pm |
Yeh that's about the prices I've been finding. |
23rd Feb 2016 5:21pm |
