Home > Technical (L322) > L322 4.4 TDV8 burnt oil smell in cabin and outside
Vogue Owner
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Java Black
Help!
Noticed a small patch of oil under the engine after my car had been sitting for a few days and now notice a slight burning oil smell in the cabin after about 20 minutes driving.
Also can smell the same smell when I get out of the car.
Haven't had chance to check under the bonnet as its dark when I leave and dark when I return.
Any known issues that worth checking this weekend? CURRENT : FFRR 2012 4.4 TDV8
GONE : Discovery 4
GONE : BMW M5
GONE : L322 Range Rover
GONE : 2007 MITSUBISHI OUTLANDER
GONE : SAAB 9-3 VECTOR SPORT
GONE : BMW M3
GONE : SIERRA COSWORTH
GONE : LOTUS CORTINA
GONE : MK1 MEXICO
GONE : MK2 RS2000
Post #350108 30th Sep 2015 7:19pm
Small oil feed pipe going into the EGR cooler that splits the oil o ring seal... Look at the top rear of the engine... If you can get it in the air you will see two streams of oil either side of the gearbox...
Find these a lot sir...
Post #350116 30th Sep 2015 8:44pm
Vogue Owner
Finally got the car back from the independent garage and apparently they changed the oil cooler and a pipe - my question is can they do this without having to change the oil?
The oil level is exactly as it went into the garage (about 1/2 full) ?
Wonder if I've been had? CURRENT : FFRR 2012 4.4 TDV8
GONE : Discovery 4
GONE : BMW M5
GONE : BMW M3
GONE : MK1 MEXICO
GONE : MK2 RS2000
Post #352697 17th Oct 2015 10:41am
Wow... So the pipe with the “O” ring was not at fault? Or the pipe with the “O” ring was what was changed along with the cooler etc
Post #352699 17th Oct 2015 10:47am
Vogue Owner
Craig - I'm in he dark about what has been changed - I was told a new oil cooler and pipe (apparently £600 cost?) but I'm still baffled as they left the car low on oil - I would have though they would have needed to drain the oil first and hence filled with oil again? CURRENT : FFRR 2012 4.4 TDV8
GONE : Discovery 4
GONE : BMW M5
GONE : BMW M3
GONE : MK1 MEXICO
GONE : MK2 RS2000
Post #352701 17th Oct 2015 10:49am
Well, its on top of the engine so the job could be done without draining the oil BUT... I wouldn’t have let the car go out without an oil change if only to make sure anything that could have contaminated the oil whilst changing the cooler was removed... Bow down
Post #352703 17th Oct 2015 10:54am
Will have to get the camera out on mine again as there was a very distinct hot burning smell when I just got out!
Funny as it was fine a couple of weeks back when I last checked it! So what else could it be folks, brakes feel Ok heat wise, it's the first time it's been run for more than 10 miles since its service though but I doubt they chucked a loss of oil everywhere..... There is nothing that can't be fixed with a hammer😜😜
Post #374147 25th Feb 2016 7:41pm
mjdronfield
Ah yes, the oil cooler in the V.... £1097 later mine was fixed. Garage just bought another 4.4 with the same issue. I think the oil cooler is about £380 plus vat from Land Rover, then the labour and oil change and coolant flushes as oil was in my coolant....
Seems a common issue then.... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #374347 26th Feb 2016 6:38pm
Smell has gone Thumbs Up not sure it was my car! Was parked in a car park.
Repeated my run backwards and it was as sweet as a nut, with no smell under the bonnet when I got home! There is nothing that can't be fixed with a hammer😜😜
Post #374423 26th Feb 2016 10:21pm
NICKJC
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Hello - I have just registered on the forum after being led here by Google search "L322 Oil Cooler Problems"
Yeah, has all the issues mentioned so far.... drips on floor and then, weeks after a huge service, an acrid smell when sitting in traffic - initial diagnosis was the new rear hubs/disks/pads (it failed its MOT on the handbrake...) but smell persisted. Car been with local dealer for a few days whilst i was away, come back to be told new oil cooler, connecting pipes and now the coolant has been conatminated so that means a full flush and refresh. On the one hand, the dealer is thorough, on the other hand a £2k service has quickly been followed by another £1k+ bill. No-one said these were cheap to run and maintain, but.....
As for the comment about oil levels, yes I was advised that the oil would not need replacing (just been done as part of the service) but it is recommended.
Bit of a pain really, had a few 300-model Disco's years ago and this is by far up there with the best cars I have run/owned, but jeez, the bills Confused
BTW I run a '61 plate TDV8 'Biography Ipanema Sand/Chocolate
Post #427593 13th Feb 2017 4:16pm
NICKJC
Sorry forgot to add that I have instructed the dealer to lodge a claim with LR UK for a contribution....will let you know if that succeeds!
17Feb: JLR rejected claim via dealer. £1400 this time! Have written to JLR customer services. Oh, and now the o/s deployable step has snapped a bracket.
Post #427596 13th Feb 2017 4:32pm
tvrforever
hmmm mine's back in to JLR main dealer when they discovered an oil leak during service (but didn't rectify it) - shall be an interesting discussion about warranty and main dealer quality I suspect Sad
Post #428396 19th Feb 2017 6:24pm
NICKJC
JLR came up with a contribution as a goodwill gesture....
Post #428877 23rd Feb 2017 8:23am
FlyingTrotter
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
This could be the same issue i have - small amount of oil under centre of car and smell noticible in cabin more when pull away from stationary in traffic - will take it to the independent
Post #505484 17th Feb 2019 5:40pm
mjdronfield
Hope you still only have water in your coolant.....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #505494 17th Feb 2019 7:15pm
