Home > Technical (L322) > windows /sunroof/opening overnight |
handyM Member Since: 24 Nov 2015 Location: stockport Posts: 19 |
Hi
1st Mar 2016 10:12am |
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 |
You don't say whether the car was still locked or unlocked.
1st Mar 2016 10:35am |
Thanks for the reply Ianv8
1st Mar 2016 10:41am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7929 |
If the key is getting worn it takes very little pressure to activate the Lazy Locking, and the key range is massive so easy to do when in the house... happened to mine with the old key, never happened with the new key.....
1st Mar 2016 10:59am |
Thanks for the reply Pete
1st Mar 2016 11:13am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34946 |
if its a new fob then i suspect its been assembled incorrectly... ... - .- -.
1st Mar 2016 11:21am |
Merv, first you are lucky it's rain water, it should dry without leaving any deposits on the PCB which causes faults, you will need to get the door panel off and remove the switch panel, leave it in the airing cupboard over night should do it... If you leave it on the water will eventually dry out but it will take a while and could cause lasting damage... plenty of "how to's" on youtube, no special tools required... I'd get the Lazy locking switched off if I were you... Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Parchment over Navy Interior. Sold 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand, Jet Interior. Sold 2002 L322 Vogue 4.4 V8 Epson Green, Ivory over Aspen Interior (Fatty Offroader) Sold -Click for Project Fatty off roader- |
1st Mar 2016 11:58am |
Thanks Pete
1st Mar 2016 12:02pm |
Hi Suggs
1st Mar 2016 12:07pm |
