Home > Technical (L322) > Really bad news, suspension electric fault FFRR MY2006
dvb247
United Kingdom 2006 Range Rover Autobiography 4.2 SC V8 Bonatti Grey
Need some help here guys Big Cry
Purchased the car 3 to 4 months ago, got a suspension 1 week in, indy swapped out the pump for a new one at the selling dealers expense in December, all good, in January I started to get the same dash suspension fault and light disabled but intermittently.
I don't do much mileage so have lived with it no issues what-so-ever, only inconvenience being that I like to lower the car when parking. I decided I'd better ask someone else to look at it and heard Land Ranger were nice guys and have good reviews, off I went and they plugged in, told me in 5 mins it was an exhaust fault likely to be the new air compressor sticking, common fault, cleared the fault and said come back if it comes on again, just to confirm.
After a couple of days, Bing! suspension fault, back to Land Ranger, same code, yep, get the new pump changed mate, so on Thursday I took it back to the garage whom fitted the pump for them to check, went back later that day and they told me I needed to "sit down, it's not the new pump, the pump shows no errors, it's an electrical issue that could be anywhere on the car, they can fix it but they have no idea how long it could take, 10 hours, 30 hours, just don't know sir?" Shocked
You can imagine how nice that was to hear as I drove home for the Easter weekend Big Cry
The BIG problem I have is that I just can't live with being told to drop my trousers and bend over until we tell you to stop, financially speaking!!! so I'm looking for some direction and even better, some technical advise so I can try some DIY tasks, I'm pretty good with general car work but electric's on these things makes me a little apprehensive as I don't know where to start!!
May not be related but my Nokia Bluetooth unit died a couple of weeks back, thanks to you guys on this forum I used the bic pen trick until I got a new one, Thumbs Up Bow down hoping for the same result on this one, such a shame as I do love these big boys toys Thumbs Up
Post #379527 26th Mar 2016 7:40pm
CS
I can't offer any technical advice, but you might like to look at the Consumer Rights Act 2015 and the Citizens Advice summary about it. I have a recollection that faults occurring within 6 months of a purchase from a dealer are deemed to have existed at the time of sale, so you might have rights against the seller. Only Range Rovers since 1988
Post #379643 27th Mar 2016 3:18pm
mzplcg
OK, some initial thoughts.
Bluetooth unit died.....That's in the NSR cubby which is a known water ingress point. LR made a water shield to divert water away from all those units. Yours, being a S/C will have lots of modules there so I would check all the connections in there.
Wheel height sensors are also known to fail sometimes. Needs an IID (or similar) to check out their readings although the wiring can be checked. Might be worth doing.
General connections. Battery, all the earth points (main 4 corners) are always worth cleaning up and tightening.
Beyond that you need to see if the car is generating codes.
Post #379650 27th Mar 2016 3:54pm
I don't know Land Ranger, but if you trust them then why not go back there and ask them ?
Who fitted the pump, were they LR/RR specialists ?
Post #379655 27th Mar 2016 4:19pm
What was the code? (not just the Message Centre fault but that as well)
Agree that with a new compressor it is unlikely to be a blocked exhaust.
What is the condition of your battery?
Any other fault codes registered? ABS? Brake Fluid Level ?
Any other work been done on your air suspension? .
Post #379656 27th Mar 2016 4:43pm
dvb247
Today I have stripped out the back end, no water or damp, however I did swap out the Nokia unit and it looked to me like it was untouched from new 10 years ago, there was clear signs of oxidisation on the large connector and inside the old Nokia unit/pins. Cleaned up the connector black and replaced the Nokia unit, all working fine now.
It's raining hard here now, storm Katie doing her thing!! but I will go through every connector on that passenger rear side. Whilst sorting the Nokia device I have been raising and lowering it a few timing and all seems good although the 1st time I went to offload height I got a slow to lift message but okay on all other attempts, maybe because I never select off road maybe?
On the drivers rear side I unplugged all relating (and non related) fuses and relays and no sign of previous water damage or green oxidisation so I think that side is okay.
I will disconnect and reconnect the EAS unit location on the drivers side dash just incase and carry out some of your suggestions.
The suspension fault message warning comes up more frequent now but I did have to short drives last week and had no problems/warnings, it seems to me that if I start the car and immediately set the car back up to normal drive height, then set off, usually no warning appear?
I think I need to buy an IID tool?, the garage that swapped out the pump are not approved, just a run of the mill garage, they said their machine was £40k and they can diagnose and fix all LR / BMW and Jags. They said the codes are not relevant as they are false codes caused by an electric fault although they said the not exhausting error was not the new pump?? I didn't get a code so I'll go back to Land Ranger and get the codes and clear them again to see if all my reconnecting of modules has worked. Thumbs Up
Post #379659 27th Mar 2016 5:15pm
Sounds like low battery voltage to me, check the voltage with engine off over night and then after a few minutes of running...
Should be around 12.4 - 12.6 and 13.5-14.4... Thumbs Up Pete
Post #379661 27th Mar 2016 5:36pm
miggit
Might be worth changing the EAS relay in the O/S/R cubby box, they are around a tenner and it could be the cause if the contacts are burnt..... it's rated at 70 amps so the internals get a bit of a kicking every time the compressor kicks in.... they are supposed to change it with the compressor... but few do Whistle Yesterday I couldn't spell Engineer... Today I are one!
Post #379695 27th Mar 2016 11:13pm
dvb247
Thanks for the help so far, been through the rear end of the FFRR and all looks as it should, no damp, water or oxidisation on any of the connectors or electrics.
Today I took a little trip out to the bank, on starting the compressor kicked in and I noticed that the rear end raised slowly, to the point where the front end released air twice before the compressor got the rear up, so I'm thinking the rear control valve is failing?
Both journeys to and from the bank with no suspension fault. Will get it checked out next week regarding code info but think I should change out the rear cross link valve and the rear height sensors as they aren't expensive, is there is WIKI DIY for these two jobs?
Post #380249 31st Mar 2016 9:30pm
Did you check the voltage, a failing battery can cause all sorts of problems...
If the valve or the sensors have failed then they will have logged a fault...
Much cheaper to get the codes read than it is to just keep changing bits.....
If your going to keep it well worth investing in an IID tool or similar, not cheap but very good resale value when you change vehicle... Thumbs Up Pete
Post #380252 31st Mar 2016 9:51pm
dvb247
Yes have been thinking of purchasing an Iid tool, would save a lot of time and money!!! I have a receipt for a new LR battery last year, could still be the source of the problem though!!
Post #380277 31st Mar 2016 11:46pm
dvb247
in the 753 diag menu the battery readings were 11.6 ignition on and 14.1 engine running, battery receipted July last year, genuine LR
Post #380635 4th Apr 2016 3:41am
ebajema
The slow rising may be an indication of leaking airbags in the suspension. With my 2006 4.2 I started having similar issues (didn't replace the compressor) and since I needed to replace the suspension rubbers, the front struts were out anyway, showing massive cracking in the fold over area. Replaced the struts and all was good after that. Does your car sink onto the bump stops after a while of sitting still ?? Do you hear hissing (needs to be in a very quiet environment) ?? MY 2010 5.0 SC Galway green and sand interior!!
Post #380636 4th Apr 2016 4:18am
dvb247
No hissing and I get very little drop when left for a few days, I've read plenty on this now and believe my FF is in the range of normal, left it for 3 week over Christmas and it only dropped approx 2"
So frustrating, been working perfect to and from work today Mad
Will get the full error code from Land Ranger in the next few days Thumbs Up
Post #380756 4th Apr 2016 8:20pm
miggit
Have you tried another £10 relay yet? In all honesty it is a well overlooked item when the pump is changed.... and as they don't have spark suppression on the contacts they will burn away eventually Shocked Yesterday I couldn't spell Engineer... Today I are one!
Post #380776 4th Apr 2016 10:39pm
