Home > Technical (L322) > What would cause oil to come out of diff breather? |
Mikeinatruck Member Since: 14 Apr 2016 Location: Dumfries Posts: 44 |
When everything is spinning in the diff its quite chaotic and the oil will be thrown to hell and back so it could just be it is blowing out the line, that said its not the norm... |
15th Apr 2016 10:27pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Sounds like the levels too high, and when it gets hot the oil expands to drips out the breather.... If you fill your own diffs then you have to make sure that the car is perfectly level... if it isn't then this can effect the level in the diff and cause the problems your describing.... As long as it's coming out the breather then there isn't too much to be concerned about... if it's coming form the drive shafts or diff nose then it is normally a blocked breather causing the problem Yesterday I couldn't spell Engineer... Today I are one!
15th Apr 2016 11:21pm |
Deanicuss Member Since: 05 Aug 2014 Location: Cornwall Posts: 77 |
My indie did the oil level on the ramps but it was doing it before this as I originally thought the diff seal was leaking. I'll get them to check the levels again. Thanks guys. |
15th Apr 2016 11:26pm |
Has the breather got a hooked top.... only if it hasn't then that could be the cause... also if it has been shortened in it's life could be another thing... Yesterday I couldn't spell Engineer... Today I are one!
15th Apr 2016 11:46pm |
It's like this
16th Apr 2016 12:05am |
The bloody photo is the wrong way round again, must be my phone. |
16th Apr 2016 12:06am |
You haven't been in deep water by any chance? only it might have filled the diff up and the oil is floating on the top... just a thought.... Yesterday I couldn't spell Engineer... Today I are one!
16th Apr 2016 12:24am |
No its brand new oil, It was done 3 weeks ago but was still coming out prior to the oil change. |
16th Apr 2016 8:07am |
Sounds like it's slightly overfilled.
16th Apr 2016 8:19am |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
Diff's are filed with a measured amount of oil (available in the wiki) not up to the top till it runs out of the fill hole .Drain and refill with the correct amount and then see if it still comes out of the breather , I'd put money on it not .
16th Apr 2016 12:41pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7925 |
And the confusion is that on the early BMW FF's the fill plug IS the level, so you fill it until it comes out...
16th Apr 2016 3:02pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
There is a landrover technical bulletin regarding this as I had the same on my 04 4.4. I'm away so can't post it as there are several causes but the way I solved mine was to drain and refill with the correct amount of oil which is different to rave.
19th Apr 2016 10:29pm |
