Home > My Range Rover > Just got my first FFRR! 2003 Vogue 4.4 |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7916 |
Doubt it's anything to do with the stat, you certainly couldn't block one with bars leaks or similar, what that will do is sludge up the bottom of the rad even more, and it's that bit that cools the gearbox, if you start getting Trans Overheat messages bonging up get a new rad asap...
17th Apr 2016 6:05pm |
mr_spock Member Since: 07 Apr 2016 Location: Welwyn, Hertfordshire Posts: 311 |
I called Aylmer and had a good chat with Neil about the cooling issues.He booked me in for a couple of weeks' time, but said I could pop down today and he'd read/clear codes. All down the A1 it was fine, then as we went onto smaller A roads she started to heat up, cool down, heat up - then I got "TRANSFER BOX NEUTRAL" messages (I think so, pixels dead makes for guesswork on that one). She still drove fine.
18th Apr 2016 4:17pm |
Sounds like a plan... that should be an easy fix... Pete
18th Apr 2016 9:45pm |
My fingers are firmly crossed! Makes it hard to type though. I don't have much luck though. Just ordered a new key fob case, at least something will work better. |
18th Apr 2016 10:14pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16176 |
I was just going to ask if it overheats on petrol as well as LPG and you answered it in your last post
19th Apr 2016 12:07am |
So far, inconclusive. Went to the village (a couple of miles) and it was fine all the way. Then on the way back the temp rose quickly, but then it switched to LPG, so it must have been warming up before that. Back to petrol for the last half mile and it stabilised and dropped a little.
19th Apr 2016 12:34pm |
Well, I don't feel this is good. A drive on petrol showed that although the temp is more under control, it's still pressurising the system. The gauge would move a mm or two, come back down, up, down etc. Then up to the right "normal" range mark, down, then up to a mm past the normal upper range. It didn't actually overheat. It doesn't seem to be rev related, or throttle opening. I'm now thinking it's not the thermostat, as that may cause temp fluctuations but not pressure, same with the rad.
19th Apr 2016 1:38pm |
Reading some more (googling BMW M62 coolant pressurizing) i find that it can be a blocked rad, rad cap or just lots of air.
19th Apr 2016 3:15pm |
This is becoming an obsession! This is a GREAT page about the M62 engine:
Clearly I need to check this. I think I probably also have air in the system. Attached pic looks like a rad leak to me. I bet the red stain is the leak stop muck. Task 1: Check the fan Task 2: Is the rad hot? Is the stat failed closed? Task 3: Bleed? New rad? |
19th Apr 2016 5:23pm |
If the stat was shut, it would boil over in about 5mins...
19th Apr 2016 5:38pm |
I think (hope) we have a winner! The viscous fan clutch seems to have failed. It should lock up when hot, and in the first 30 seconds after start up. In both cases I can stop it with a newspaper. The rad is hot all the way to the bottom, and there's the sound of pressure escaping the expansion bottle at the cap.
19th Apr 2016 6:13pm |
I did check on petrol, same behaviour. See my other post just now, fan seems to be dead which (from the BMW engine link) seems to match my symptoms exactly with the rise/fall of temp and the lack of issues at speed. |
19th Apr 2016 6:15pm |
If it's not working then that could be it... Although the aircon fan should come on if the viscous can't cope to prevent overheating so maybe that ones defective as well....
19th Apr 2016 6:33pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2026 |
i bought a new viscous fan for mine, online, it was around £70 this was aftter i was quoted £150 for a secondhand one, ('with some chisel marks on the nut...') from some idiotic dismantler, i said i didnt need the rest of the engine, that was no doubt screwed to it still, and told him where to go. new one cured my slow spinning fan. as said, they are very 'windy' at 1st start, and then they sort of ease off as the engine comes down, then they are very quiet. i cant remember the make i got, but it was a think from an ebay seller. -has been good for three years now.
19th Apr 2016 6:51pm |
