Home > Technical (L322) > Suspension won't raise from standard height setting |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
Looks like your air suspension compressor isn't producing enough air.
24th Apr 2016 6:46am |
6029 king Stephen Member Since: 11 Apr 2015 Location: Sittingbourne, Kent Posts: 101 |
Thanks for the suggestion. I will have a look at Island 4x4 website as they have so far provided all spares I have asked for with fast courier delivery. Failing that, I will look on eBay. I'll need to get the part sharpish as I only have week before leaving for Gabon.
24th Apr 2016 7:31am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16176 |
Steve, do you have a diagnostic tool? IID etc? You really need to be able to check live data to advise you! Yes the compressor could be week, you could have a leak (above standard height) hence it won’t lift! etc etc etc |
24th Apr 2016 10:13am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7924 |
If it goes from access to standard and drops and raises from motorway to standard then there can't be much wrong with the compressor, not wishing to teach you to suck eggs but you do know it won't do anything with a door open...!!!
24th Apr 2016 2:41pm |
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 416 |
As said above it could still be a leak. Mine was similar, worked fine in standard and motorway but would take ages to go into off road height and eventually wouldn't even go that far.
24th Apr 2016 6:07pm |
