Home > Maintenance & Mods (L322) > very slow seatbelt retraction on both front seats
Ohwhatalad
United Kingdom 2013 Range Rover Vogue SE SDV8 Corris Grey
hi all, ive seen a few posts about this but mostly it seems to be due to the seat belt being gunked up with rubbish mine seems fine
it has a very strong pull but this part at the top slows it down to a crawl, sometimes not even going back at all
i cant see any way of opening this part up to clean it, has anyone ever had this part replaced and does it fix the problem?
PS im talking about the black plastic part where the belt goes through
Post #383489 24th Apr 2016 2:00pm
Pvw10
United Kingdom 2014 Range Rover Vogue SE SDV8 Firenze Red
I had this on my car plus my X5 and learned a trick on a X5 forum.
Buy a can of silicone spray in clear, pull the seat belt all the way out and spray the belt all the way along both sides. Be careful where overspray goes and it works a treat and lasts for ages. Many thanks
Paul
Post #383491 24th Apr 2016 2:06pm
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
Try cleaning the belt itself, I need to do mine as I get the same and have to feed it in the last bit.
This explains it and shows the fix:
Furniture polish on the belt is another trick I've seen.
Post #383493 24th Apr 2016 2:09pm
coincidentally i just did mine with a wet wipe that i used to clean the leather...seems to retract better now.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #383495 24th Apr 2016 2:12pm
It'll make a small difference but the trouble seems to be within the seatbelt itself, that bit at the top does stop it somewhat but it is the return spring in the seatbelt itself... you can't change any part of the seatbelt, for one thing they don't sell bit's and you can't get it apart and back together anyway..
I have had mine out, fully cleaned and used a bottle of silicon on them, even bought a second hand one which was just as worn, although retracted with some force when not fitted... took it apart and that was it... it's made and restrained in one hit, no way to tighten it up or fix it at all...
Try the silicon it get's a bit better but ultimately you need a new one, they are about £140 IIRC from Dan.. Thumbs Up Pete
Post #383503 24th Apr 2016 2:31pm
They are available for one model year at around £60... Maybe an 09>???
Post #383506 24th Apr 2016 2:41pm
Interesting Craig, I did find different numbers for them, some to do with colour and some with years... maybe worth a chat with Dan... Thumbs Up Pete
Post #383509 24th Apr 2016 2:48pm
Indeed... Thumbs Up
Post #383513 24th Apr 2016 2:54pm
Try LR010936 Pete Thumbs Up
Post #383514 24th Apr 2016 2:58pm
Ohwhatalad
thanks guys very helpful, i think it does just need new ones but ill try with some sillicone spray first to see if it makes it any better Thumbs Up
Post #383518 24th Apr 2016 3:06pm
Cheers Craig, just got a brand new one off eBay for £50 delivered so we shall see if it fit's OK....
Have to get a passenger one if it fits as it will look odd with one green and one black... Rolling Eyes Pete
Post #383554 24th Apr 2016 7:14pm
Ohwhatalad
let us know how you get on please pete, ill order 2x if they fit and work well.
i guess seat needs to come out again to fit this?
Post #383560 24th Apr 2016 7:41pm
mzplcg
Interesting. I had the same on SWMBO's Jag XF. Cream belts which were looking grubby so I cleaned them with a wet vac. I wasn't trying to cure the slow retract but it did fix that too. If you'd seen the colour of the water in the vac after I finished you would have been quite shocked. It was beyond filthy.
Post #383572 24th Apr 2016 8:39pm
It fits... Thumbs Up
See here
http://www.fullfatrr.com/forum/post384129.html#384129 Pete
Post #384130 27th Apr 2016 8:16pm
rathbranV8
Ireland 2002 Range Rover SE 4.4 V8 Oslo Blue
Furniture polish like mr.Sheen if you have it around.Pull belt out fully and spray both sides.Did it to mine for test recently.Saves buying silicone spray Thumbs Up
Post #384475 29th Apr 2016 5:33pm
