Home > Technical (L322) > Creaking Back End |
idrawcad Member Since: 13 Jun 2014 Location: Sunny Bournemouth Posts: 144 |
My 2003 FF has developed a creaking noise at the back end. It only creaks when its suspension is raised to road height or above, it creaks over every bump, sounds like a rubber on metal creak and not a grinding metal to metal creak. If I bounce on the rear bumper it creaks. it sounds worse on the drivers side. When it settles to parked up height it creaks as it goes down.
26th Apr 2016 8:56am |
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 559 |
There are a lot of bushes on the rear suspension - all of which will give you a creak or rattle when going over a bump.
26th Apr 2016 10:13am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7934 |
It will definitely be the rear upper hub bush, which is an enclosed heim joint, they squeak like crazy when worn, it's awkward to flex it to see movement but hit it with 1/2 a can of WD40 and I bet it shuts up for a day or two...
26th Apr 2016 5:16pm |
Thanks Pete,
26th Apr 2016 6:48pm |
You may have to move the rubber cover out the way... mine had large bit's missing...
26th Apr 2016 7:26pm |
Hi Haylands,
20th Jun 2016 9:51am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6400 |
Outer bushes are fairly accessible so labour about the same as the bushes which are £30 - £50
20th Jun 2016 1:07pm |
