Home > Technical (L322) > EGR warning - post mortem findings |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Think that you need to read the reg's again buddy, if you put a new engine in an old car then it has to meet the emission standards for the age of the car....... however if you put an old engine in a new car then it has to meet the emission standards of the year that the engine was manufactured........ that's a win win, if you can be bothered to go through all the hassle of the engine change and integration now running on the logic that the EGR's are eltriceral, and that they supply a signal back to the ECU to report on which state they are in, can it not be faked? My other car ( sorry can't name it, or Pete will go in to one, but it's a tri-pointed badge ) has electronic operated swirl flaps but they have found that you can do away with them and fool the system with a resister I think that the EGR is of a similar design..... but I'm still sorting out other things before I get around to open engine surgery...... anyway it's running too well at the moment and returning 37 MPG Yesterday I couldn't spell Engineer... Today I are one! Inventor of the 'Guide-o-Matic automatic wheel alignment tool' Former long term L322 owner, Up/Down graded to a Classic Tractor! |
1st May 2016 5:55pm |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 605 |
Forgot they could also be doing load sensing on the motor. Ed |
1st May 2016 6:14pm |
Got a feeling that they is either open or closed and there is nothing in between except when they are all crudded up
1st May 2016 7:11pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7924 |
No, far from "Really" I was speculating, that's why I used words like "wonder" and "probably" I've read hundreds of threads on many different car forums about how much better diesel engines run and behave when the EGR is blanked off or tuned out so one would presume that the TDV8 would be similar.... I was trying to encourage a discussion about an issue which is very much talked about on this forum, at no point did I state any facts or pretend I am an Internet "expert" I don't, however, believe everything I read and I certainly don't believe everything I'm told.......... Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Parchment over Navy Interior. Sold 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand, Jet Interior. Sold 2002 L322 Vogue 4.4 V8 Epson Green, Ivory over Aspen Interior (Fatty Offroader) Sold -Click for Project Fatty off roader- |
1st May 2016 7:19pm |
Your the BEST PETE Like you bud, I fail to see how an engine that requires a good supply of clean air will run well when it's forced to breath some of the exhaust..... it just doesn't make any seance Having been doing a fair bit of searching about VGT turbo faults.... the biggest cause of failure is soot clogging up the works..... just about the same as the EGR's..... from what I can see you need to replace the missing sulphur in the fuel with either an additive or 2 stroke oil.... this would appear to be the best long term remedy. If you can keep the engine looking like it's just left the factory inside , then everything should work..... When the vanes get clogged up and stop moving in the turbo, it causes over boost... which leads to things going pop and Some cars appear to have a boost censor that detects the overboost and puts the engine in to limp mode.... Land Rover seam to have done away with this and just rely on the the induction system exploding resulting in a limp engine Yesterday I couldn't spell Engineer... Today I are one! Inventor of the 'Guide-o-Matic automatic wheel alignment tool' Former long term L322 owner, Up/Down graded to a Classic Tractor! |
1st May 2016 7:38pm |
I don't think you will have much trouble, your engine will get a good work out towing the crappers around...
1st May 2016 8:10pm |
Based solely on the IID Tool readout the EGRs on the TDV8 are not just open or closed as it reports a percentage and I've seen it reporting that on test drives when I was evaluating the EGRs.
1st May 2016 10:12pm |
Well I don't reckon much on L/R software then.... a pal of mine has just copped hold of a VW Touareg and that keeps on going in to limp mode rather than blow everything to pieces But we don't care cos there's a cheap fix with Mr Muscle Oven Cleaner and some rubber gloves OO ER Matron Yesterday I couldn't spell Engineer... Today I are one!
2nd May 2016 12:25am |
You'll quickly realise that most car manufacturers can't or don't write software particularly well.
2nd May 2016 6:29am |
