Home > Maintenance & Mods (L322) > Do My Brake Discs Need Replaced? |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 |
Gentlemen,
9th May 2016 7:54am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34940 |
i would replace Si.....if you're fitting new pads then the extra effort and expense to fit new discs is certainly worth it... ... - .- -.
9th May 2016 8:11am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7927 |
What Stan says... with brakes, steering and suspension I always err on the side of "if in doubt, change it"
9th May 2016 8:31am |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7789 |
Another vote for doing it |
9th May 2016 8:51am |
Thank you, gentlemen.
9th May 2016 9:11am |
I think I change discs every 2-3 sets of pads as it's only a couple of hundred quid so would always err on the side of caution if changing the pads anyway
9th May 2016 9:22am |
The workshop manual will give a minimum thickness that they don't recommend going below, so technically it is not a subjective matter, yours look like they will be very close to the minimum, especially the fronts. Most mechanics will give you advice based on looks as opposed to the actual measurement, both you have spoken to are correct, you could get away with another set of pads without issue, but the discs could do with replacing... sounds weird but true.... Nothing wrong with asking for a second opinion, either on here or at another garage...
9th May 2016 9:32am |
Sage advice, Alistair and Pete.
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1490 |
@ Haylands
9th May 2016 9:39am |
Si, it might be worth mentioning that using aftermarket pads might give you problems as i did..changed my pads to OE from ducky dan and all is well.. ... - .- -.
9th May 2016 10:19am |
Stan - good advice as always.
9th May 2016 10:34am |
thanks Si..
9th May 2016 11:04am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16176 |
Si,
9th May 2016 11:52am |
Craig, thank you.
9th May 2016 1:37pm |
