Home > My Range Rover > Just got my first FFRR! 2003 Vogue 4.4 |
Wylie66 Member Since: 10 Jan 2016 Location: Bushey Posts: 67 |
Good to meet up with you today Ian
14th May 2016 5:08pm |
mr_spock Member Since: 07 Apr 2016 Location: Welwyn, Hertfordshire Posts: 311 |
Apart from the saga of multiple skip delivery attempts (6 so far, they finally got it right)...
18th May 2016 12:15pm |
Well it's ready. And I'm now told the BRC LPG reducer is peeing water, which it wasn't doing at the weekend. Great. |
18th May 2016 1:33pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7908 |
They probably moved one of the pipes and it's old and hard and now cracked, if it's the vaporiser itself then pretty sure they still do an overhaul kit with the "O" rings needed... Pete
19th May 2016 9:30am |
They only did the exhaust and front strut, so I can't see why they'd have been around the vapouriser. I tightened up the allen bolts holding it together, let's see if that helps. I'll have a look later.
19th May 2016 9:39am |
That's a brand new one, yours will be full of heavy ends, a black tar like substance that comes from the impurities in LPG, it will also be corroded and probably difficult to get apart...
19th May 2016 10:49pm |
I ordered a kit from lpgshop.co.uk. They were cheaper from eBay, but lpgshop allows returns within 30 days of unused stuff, so playing the odds, it may get me on the road faster. I'll open it up today/tomorrow and see how it looks. |
20th May 2016 7:10am |
Inspired by your post I whipped the vapouriser off. The split in the seal was obvious even before I opened it up. The good news is that it's as clean as a whistle inside, no gunk or, well, anything. Just waiting for the seal kit now. |
20th May 2016 9:09am |
Wow... little use then, the one on mine was about 4 years old (it had a date on it) and was so corroded and gummed up I had to use a chisel to get it apart... It then got worse inside so it went in the bin...
20th May 2016 9:19am |
It turned out to be easy to fix the vaporiser. Bolts out, hit gently with a hide mallet to split it, replaced the split gasket and left everything else the heck alone! There's a second gasket with a metal part attached but I couldn't for the life of me see how it went together, so I left it. The gasket (the red one) was still supple so left it.
23rd May 2016 10:02pm |
Going well Ian..
23rd May 2016 10:20pm |
Glad it was something simple! Did it take out the O2 sensors too? |
24th May 2016 8:43am |
Not sure, but the EML hasn't illuminated since.. However further info gleaned from previous owner suggested that when he had it Mot'd the garage cleared the faults and it passed emissions with now issues at all, they sai if it failed them then they would change the sensors.. I will see what happens if the EML comes back on again.
24th May 2016 9:13am |
ECP have a nice 25% discount this weekend, so ordered spark plugs and wipers. They were cheaper than GSF with their 45% discount!
30th May 2016 2:03pm |
