Home > Maintenance & Mods (L322) > Sounding like an old slivercross pram |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1242 |
2 ball joints at the bottom of each suspension strut, could be either of them. On each side the whole setup is a combination of 2 arms (1 includes the ball joint ) and ball joint.
26th May 2016 11:21am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7908 |
If they are OK or it only does it when you steer then it could be the rack end, not the track rod end, but the bit that it fixes to and connects it to the steering rack, they have a nylon ball joint, it dries out and squeaks like a goodun when worn...
26th May 2016 12:00pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2025 |
could you not spray some joints, with say some motorbike 'chain lube' on a straw to get the affected area and drive it to see if you have 'found it' then deal accordingly, -i have to admit i had a sort of creak, that turned out to be a loose wheelnut. some people have had brake caliper 'noises', dont spray those.
26th May 2016 12:44pm |
forever Member Since: 06 Oct 2015 Location: Oxted Posts: 319 |
thanks all, defo seems to come from the front, strange that something needs to warm up before it starts, also does make the noise but not as loud when stationary and turning the wheels... |
26th May 2016 1:13pm |
So to round this off, went into Landrover today for the brake recall, they did a health check all passed bar both sides antiroll bars warn, so I guess this is what's causing the noise...
29th Jul 2016 7:33pm |
Anti roll bar what...???
29th Jul 2016 10:44pm |
Report says front and rear anti-roll bar link... |
30th Jul 2016 10:11am |
Originals are around £30 each IIRC... hours work to change all four...
30th Jul 2016 1:22pm |
Thanks strangely not make a noise at the moment at all , sigh don't you just love them, I don't really have a local indie, there is a good general garage but no LR specialist.. |
30th Jul 2016 1:44pm |
It's back , took a video do we think it's the anti roll bars?
30th Jul 2016 2:27pm |
The jury is out on that one I'm afraid, doesn't sound like ARB links or steering but then it always sounds funny when you record it....
30th Jul 2016 3:27pm |
