Home > Technical (L322) > Odd Gearbox Symptom 03 V8 Petrol V8 or poss Diff |
Wylie66 Member Since: 10 Jan 2016 Location: Bushey Posts: 67 |
I have done some cursory searching but wondered if someone can give a quick answer.
2nd Jun 2016 9:28am |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 912 |
Clutch engagement issues which are 1) fluid temperature dependent and 2) engine speed dependent usually indicate a leak in the hydraulic circuit somewhere. For the ZF 5HP24 transmission clutches C & F are used for reverse and neither of these clutches are used in any of the forward gears.
2nd Jun 2016 10:32am |
Thanks for the prompt responses.
2nd Jun 2016 11:38am |
If you’re getting overrun braking in manual mode in 1st gear then it sounds like a C clutch issue. Could possibly be the O-rings on the D/E clutch drum support bush or worn phosphor-bronze bushes in the sun gear sleeve, both of which act as seals for the C clutch hydraulic activation circuit.
2nd Jun 2016 12:35pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7929 |
Diffs can't have anything to do with it, if it doesn't engage reverse, a nasty clonk when it was engaged could be the diff...
2nd Jun 2016 12:42pm |
Superb info, thanks guys.. I see what RRPhil meant by leakage now.. my naive mind was thinking they fixed leak but he meant leakage past seal. I will call transmission place and get their take on it. is it a hard job to replace the C clutch? 2003 V8 Vogue in Silver |
2nd Jun 2016 3:45pm |
If I were them I’d drop the sump and the valve body assembly and apply air pressure to the C clutch to check for leaks before going to the trouble of taking the transmission out. Unfortunately the seals/bushes we discussed are buried quite deep within the transmission so the whole thing would have to be stripped to get at them.
3rd Jun 2016 12:07pm |
