Home > Technical (L322) > -08 TDV8 gearbox occasionally hard gearshift. |
SveinHa Member Since: 22 May 2016 Location: Karmøy Posts: 36 |
Every now and then the gearshift is far from as smooth as it is supposed to be. From standstill, the shift from second to third gear is the one shift that most frequently fails. It may be wrong to say "fail" but the shift is far more abrupt than expected. When manually downshifting on enginebrake it also sometimes seems to overcompensate rpm so that when engaging a lower gear, the rpm is slightly too high so that you get a slight acceleration before continuing engine brake. It's not much, only a quarter of a second or so but the gearshift is far from smooth. Any good ideas on what may be the cause of this behaviour?
7th Jul 2016 10:18pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 912 |
Faulty solenoids are a very common issue on the 6HP26 transmission.
7th Jul 2016 10:32pm |
Makes sense. I would assume they are fairly easy to change with the gearbox in the car? "Plentraktoren/Garden tractor": 2008 L322 TDV8
7th Jul 2016 10:35pm |
Yes, just drop the Mechatronic unit out of the sump.
7th Jul 2016 10:40pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7927 |
Bl00dy spellcheck... Pete
7th Jul 2016 11:33pm |
FFS There is nothing that can't be fixed with a hammer😜😜
7th Jul 2016 11:39pm |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
My 6hp26 failed last year as the output spline had no anti corrosion/lubrication, which also affected the TC input gear. I was lucky to pick up a good used box. I'm currently reusing the original mechatronic. There was no sign it was failing.
8th Jul 2016 2:39am |
Visited my local RR dealer to troubleshoot the gearbox. They told me the box had to be rebuilt or replaced due to mechanical problems.
8th Sep 2016 8:19pm |
