Home > Technical (L322) > [ SOLVED ] Door open message even though doors are closed. |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 818 |
Hi all and sorry if this has been done to death but I can't find a definitive answer to this annoying problem.
22nd Jul 2016 10:05pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7916 |
Open and slam all the doors, boot and bonnet a couple of times, you may find it goes away... If not try a battery disconnect (see WIKI)
22nd Jul 2016 11:03pm |
Hi Pete, thanks for info but I've tried the slamming of the doors, so much so that my neighbours must have thought PMT was finally kicking in.
22nd Jul 2016 11:07pm |
Personally I wouldn't have one, the IID is the class leader and does everything the dealer can do and more, the back up from GAP is superb...
22nd Jul 2016 11:21pm |
Thanks for the advice, I'll have a poke around on the Gap site..... ______________________________
22nd Jul 2016 11:31pm |
I've decided to go for the IID Tool as it seems to give the best all round performance for the price. The problem still remains with a latch I think, can't check which one as I don't have my IID yet but I did strip down the drivers side today but no change.
25th Jul 2016 7:50pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3954 |
Do your indicators flash once when you lock the car with a key fob? |
25th Jul 2016 8:29pm |
Yes they do.. ______________________________
25th Jul 2016 10:28pm |
Good advice thank you. The suspension is inactive as I can't change the ride height at all. I toggle the switch to say - off-road height and the LEDs just flash and no change in height, even after waiting a minute or so, it's the same with access height on either the door button or the suspension toggle on the dash.
26th Jul 2016 8:49am |
Unfortunately despite what I said above what you say about the air suspension not moving tends to suggest it's one of the passenger doors causing the problem not the tailgate. The tailgate being open doesn't inhibit the air suspension changing height.
26th Jul 2016 9:09am |
Hi, ok so I've just checked the tailgate and it latches securely with no movement at all, I even activated the latches with a screwdriver to simulate it being shut and no difference.
26th Jul 2016 9:11am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
Did you try battery disconnect (often resolves a multitude of sins, resets ECUs and banishes electrical gremlins back in their box (for a while )) or are you going to wait for your IID Tool to show up? .
26th Jul 2016 9:57am |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3196 |
26th Jul 2016 10:09am |
Hi and thanks for the suggestions. I've tried the battery disconnect but nothing changed so I'm just going to wait for the IID to show up.
26th Jul 2016 10:21am |
