Home > Technical (L322) > The Range Rover hasn't even moved....... |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 818 |
Hi All,
27th Aug 2016 4:00pm |
Hi,
27th Aug 2016 4:14pm |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2543 |
Simon, thats about the depth of my help, hopefully someone with more skill will be along soon |
27th Aug 2016 4:25pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1692 |
What fault codes are you getting with the IID? |
27th Aug 2016 4:53pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
And check the gearbox oil temperature with your IID Tool .
27th Aug 2016 5:41pm |
Hi,
27th Aug 2016 7:01pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
Have you jacked it up recently with the wheels hanging down or touched the height or ABS sensors as these can cause all sorts of problems as can a dodgy battery.
28th Aug 2016 12:49am |
Hi Chicken,
28th Aug 2016 8:11am |
Naked bar or spoofing for drinking a pint of pi55? |
28th Aug 2016 8:29am |
To me it sounds like your problem may be low voltage at tick-over from the alternator. If the alternator is not charging very well at the low RPM, than the voltage will drop and that generates all kinds of interesting faults in a FFRR !!!
28th Aug 2016 3:07pm |
Hi,
23rd Sep 2016 2:22pm |
I would be checking all the earths, battery terminals, etc. A bad earth will also cause voltage drop, especially as load increases. |
23rd Sep 2016 2:34pm |
It would certainly be worth checking all your wiring and have a google about in depth testing the alternator but i think it would point towards the alternator as should be charging at over 14 volts.
23rd Sep 2016 5:20pm |
Cheers my friends, I'll have a go with all of your suggestions especially the earthing points.
23rd Sep 2016 10:49pm |
