Home > Technical (L322) > Hard shifting. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7934 |
I'd get it looked at by a transmission shop, obviously something wrong with it... may get away with just an oil change if you're lucky... There is no adjustment on the box so if that doesn't work they will have to dig deeper, if they know what they are doing they can measure resistance in the valves in the valve block which may indicate an electrical problem...
8th Sep 2016 10:23pm |
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 |
Thx for response!!
14th Sep 2016 9:30pm |
That's doubtful to be honest. The issue is with the transmission. If you catch it in time you might get away with a fluid change as Pete said. Failing that you could get the valve block serviced to see if that improves matters. Beyond that it would likely be a replacement tranny and torque converter. |
15th Sep 2016 7:37am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16185 |
Also worth checking the software is NOT corrupt!
15th Sep 2016 9:45am |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 913 |
May also be worth having the 2nd clutch accumulator checked out to make sure that the spring hasn’t broken
15th Sep 2016 10:30am |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
Mine had hard shift not long before it toasted altogether, either 1 or 2 broken springs in the accumulater besides quite a few other items including the tc. Best get it checked. |
15th Sep 2016 11:26am |
I tried many times today.
15th Sep 2016 1:46pm |
