Home > Technical (L322) > 6HP26X multi plug leak |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1698 |
Remove sump, pull down locking tab which releases the sleeve |
10th Oct 2016 9:13pm |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 605 |
That's what I suspected. Thanks for confirming Mikey. Oh well give it another oil change whilst I'm at it then, better check how much I have left over from the one a short while ago... Ed |
10th Oct 2016 9:15pm |
Hammer Member Since: 14 Oct 2012 Location: Perth Posts: 123 |
I have the same symptoms. Is there a post/details for the repair somewhere?
11th Oct 2016 2:46pm |
Phil's mentioned it over here
11th Oct 2016 3:14pm |
Thanks Ed 2015 AB 5.0 Supercharged
11th Oct 2016 11:06pm |
No worries, the ZF procedure is over on disco3.com (hopefully that link works from my mobile).
11th Oct 2016 11:20pm |
Well job done, only difficulty was that the sleeve is in a difficult location. Old one came out no trouble at all one the latch was released. Pushing the new one in was a little tricky. You must line up the notch on the sleeve which is about 5 o clock on the gearbox.
15th Oct 2016 4:51pm |
