Home > Technical (L322) > Aux Heating |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1620 |
I believe aux heating only activates over 15 degrees ambient. Is it the original fob? They do need pairing with the car and even if original may have lost pairing at some change of battery etc.
7th Oct 2016 3:57pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3196 |
Park heating will only come in if ambient is less than 16 C. Cooling only if over 16 C. If you have changed the battery then, as suggested, you may well have to pair the remote again. First thing to try.
7th Oct 2016 5:06pm |
Jase71 Member Since: 13 Apr 2016 Location: Portsmouth Posts: 479 |
Okay, the latest is I have put new batteries in the remote, waiting until the temp was below 16 deg C, pulled the fuse to resync but the result is nothing happens with the heating. I get a green light on the remote for a few seconds and then that's it.
12th Oct 2016 12:27pm |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
Pulling the fuse doesn't seem to work on post 2006 cars , so find the receiver unit in the right rear where you will find it on the back of the mounting bracket and sync your remote by pulling out the power lead . 2008 MY Supercharged
12th Oct 2016 1:04pm |
Thanks Axle, but how do I find out if the FBH itself is faulty? |
12th Oct 2016 1:32pm |
Have you tried running it from the display screen? John
12th Oct 2016 1:34pm |
Yep |
12th Oct 2016 1:35pm |
and? John
12th Oct 2016 1:36pm |
Just re-read your first post. Suggests your FBH is broken. John
12th Oct 2016 1:38pm |
Manual Button just goes green then red for a second and nothing happens.. |
Is there a fuse for the fbh just to check the obvious😎 |
12th Oct 2016 1:40pm |
Not sure if it's the same for your MY but on mine fuse 59, 20 amp.
12th Oct 2016 1:52pm |
Just checked and fuse is fine Have no idea where to fault find next! |
12th Oct 2016 2:01pm |
Update, pulled fuse 56 and then did system reset diagnostic test and now the fans are running when I press manual and via the remote. Does the fbh not turn on unless ambient temp is colder? |
12th Oct 2016 3:16pm |
