Home > Maintenance & Mods (L322) > Retrofitting fitting paddle shift to a 2010 5.0 Supercharged |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34925 |
interesting question.... ... - .- -.
17th Sep 2015 7:38pm |
Didn't think I would use the flappy paddles on the diesel, but find myself playing with them all the time. They are useful when coming to overtake, you can blip it down a couple of gears in readyness for the move. More relevant on the diesel with the rotary knob as the sport mode doesn't have a way of manually selecting the gears other than the paddles unlike the sc where you could (if you didn't have them) flick the gear-lever to the left.....
17th Sep 2015 8:25pm |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3646 |
I just wanted the engine braking as well but I'm sure I'll also be changing down to get the supercharger spinning as I plan my next overtake Geoff |
17th Sep 2015 8:49pm |
SCPB Member Since: 16 Jun 2015 Location: Surrey Posts: 72 |
So the list is building. I'll just paraphrase and add a couple more:
17th Sep 2015 10:46pm |
Mine are now sorted and working perfectly thanks to the guys at GAP Geoff |
17th Sep 2015 11:19pm |
Excellent, well done. 2010 5.0 SC Autobiography |
17th Sep 2015 11:20pm |
I think I was probably of the mindset of what's the point in having paddle shifters on my SC when it has power to spare. However in my first proper drive all has become clear, using the box to slow the car down, holding the car in second or third to perform a quick overtake, kick down takes valuable time. it is also nice to have the option of engaging "sport" via the stick for around town driving.
20th Sep 2015 5:52pm |
Vineyard Dog Member Since: 24 Jul 2016 Location: Napa, CA Posts: 5 |
Hi All, I joined this forum because I was so excited to learn that this mod could be done. Short story is I'm a full supporter of the paddles. I just drove around the mountains here for two weeks on a vacation with lots of ups and downs and just the stick for shifts all the while wondering why they didn't give me paddles in a '12. The rig went in for new brakes after vacation and they gave me a loaner, which had paddles! What a revelation. That prompted me to see if there was a mod for mine and lo and behold, there is! I've read the threads on this and other forums. I can figure out the airbag stuff as I did this on my 135i. What I need a little more assistance on is the jumper cable. Does anyone have a pic of the ebay cable showing a the connection between the paddle harness and the empty slot on the wheel? Maybe it's the subtle differences between how the Brits are describing the cable to my Yankee English, but I guess without having the parts in front of me, it's a little tricky to understand the whole "lining up the cables and then rotating 180 degrees". Thanks in advance. I can't wait to try this! |
24th Jul 2016 10:55pm |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 |
As you have a 12 plate these can be fitted without any modification to the system. You just need to fit the paddles, connect them to the connector behind the airbag and then get your CCF (Car Config File) modified to enable the paddles which can be done with diagnostic equipment like faultmate or maybe even at a dealer
25th Jul 2016 9:15am |
I'm getting conflicting info on whether an American 2012 is wired the same. No matter. I'll get the extension anyway, but, any of you tell me what the torque spec is for the steering wheel nut? |
29th Jul 2016 1:46am |
Hey guys, I have a 2012 HSE 5.0 North American RR. My indy shop needs help. I've got the paddles installed and they appear wired correctly as they light up. The shop plugged in the Autologic unit and after searching through menus for 10 minutes, was unable to find any option to activate them. He asked that I do more research on where exactly the item appears for a 2012 HSE. I was hoping someone could map out where this appears? Do I need to take the next step and have him reflash the trans so that the options can be selected during the reprogram? |
18th Aug 2016 8:15pm |
Bluegreygreen Rangie Member Since: 10 Aug 2012 Location: Australia Posts: 53 |
Im just wondering did Gap supply the updated transmission ecu file?, If not is it available or do i have to see a dealer? I have fitted the paddles's and activated with Gap however my car is 09/2010 so i no doubt need the update as they are not working Dave 2010 TDV8 Autobiography Past - 02 & 03 TD6 And an 1984 Classic GAP Diagnostics |
26th Nov 2016 5:07am |
j_rov Member Since: 10 Jan 2017 Location: Warwickshire Posts: 385 |
For anyone new to this thread with a 3.6 TDV8 10MY vehicle. It's not possible as the gearbox is missing the hardware needed.
5th Sep 2018 2:51pm |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 |
Offer still standing guys - including free delivery at the upcoming show! l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l Current RANGE ROVER Vogue 4.4L SDV8 - 2013 - Indus Silver, on Almond. RANGE ROVER Vogue 4.4L V8 - 2002 - ex-2003 G4 Challenge Event Vehicle, Stage 3: Australia RANGE ROVER HSE 4.4L V8 - 2004 - one-of-one Overfinch RANGE ROVER P38a 4.0L V8 - 1999 - ex-2000 TReK Event Vehicle: South Africa Previous: RANGE ROVER Vogue 4.4L TDV8 - 2012 - RANGE ROVER 3.6L TDV8 x3 - RANGE ROVER Td6 x1 - RANGE ROVER Classic 3.5L V8 x1 |
5th Sep 2018 6:19pm |
