Home > Maintenance & Mods (L322) > Keys keys keys
Sandyt
Keys keys keys
Gents so here is the dilemma I have three keys now but only one works off the fob when I or indeed the workshop reprogram any key it works but knocks the others out all start the car and unlock on the blade oh its a 2007 4.2
Any ideas how to get at least two working off the remote?
Post #418717 19th Dec 2016 10:15pm
So all 3 keys work independently - but not together ?
Sounds like the problem must be with the receiving module in the car then - for some reason it is only recognising the last key programmed.
Post #418719 19th Dec 2016 10:47pm
Sandyt
Yes thats what I thought took it to the dealer and they dont have a clue but it literally just takes the last key and drops the others yet they still open the doors and start in the ignition just no fob
Post #418720 19th Dec 2016 10:54pm
3528cc
United Kingdom 2008 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
Might not help, but on a RR Classic if you reprogram the key fobs, you must do all of them together (max 3 iirc)
If you only reprogram one, only one will work, as the codes are changed in validating previously fobs Regards
Royston
2008 4.2 Supercharged Autobiography
1994 Classic Vogue SE
1999 Rover BRM
1987 Rover Vitesse Twin Plenum
Post #418721 19th Dec 2016 10:59pm
Sandyt
Its the same on these and yes we are doing all three at once and it is only the first one in the sequence that hold the others drop out then if I change the order and start again it is only the first of the 3 that it holds
Post #418722 19th Dec 2016 11:08pm
Weegie
You know NOT to put the second and third key into the ignition when doing the sequence.? It sounds as if you are putting each key in turn into the ignition which has the effect of restarting the procedure??
i.e. Put the first key in the ignition and do the synching process, then, without putting the second key in the ignition, do the synching process on it, same for third key.
At end of synching try the keys. John
GAP iiD BT
Post #418752 20th Dec 2016 9:51am
