Home > Technical (L322) > Removing ball joint - at wits end |
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 479 |
HELP!!!
28th Dec 2016 8:41pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34939 |
any help?
28th Dec 2016 8:47pm |
Saw that thread last night whilst researching.
28th Dec 2016 8:49pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
This job is a PITA!
28th Dec 2016 8:57pm |
That's what I originally tried doing, getting the arm off the ball joint, but it just wasn't happening!
28th Dec 2016 9:05pm |
I tried that earlier, just couldn't get it to go |
28th Dec 2016 9:33pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7927 |
Even if you get the bolt out I bet you can't get the balljoint out the hub, needs some serious abuse to remove it, stick the nut back on and put the bolt and nut back in the other end and take it to the garage.... Pete
28th Dec 2016 9:35pm |
3528cc Member Since: 29 Oct 2014 Location: North East Posts: 301 |
As above, If you can, might need a helper....... if you are also using a fork to apply pressure
28th Dec 2016 9:38pm |
Thanks for the advice, will try again tomorrow I guess!
28th Dec 2016 9:43pm |
Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267 |
Not done this one but if it is a real c^£t give it a good spray up.start again tomorrow,get a big bar and a blowlamp,try and get the weight off it or even better to help you ,get it hot if it is possible and whilst giving it a bloody good bar hit it very hard with a good long handled hammer,helps if you have a mate to help,two hammere work even better together but take care that you don't get carried away and cause any damage elsewhere .Good luck . |
28th Dec 2016 10:57pm |
DO NOT use any heat on it you will boil all the grease out the wheel bearing, a club hammer usually works but difficult to get a good swing when the car is on a jack, helps if it's on a ramp, it's so much easier....
28th Dec 2016 11:24pm |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 |
I had a similar problem with the ball joints a couple of years ago. I ended up using a long arm fork ball joint remover and a sledge hammer. Still to about 15 minutes of beating before joint split 56 TDV8 Vogue SE
29th Dec 2016 12:07am |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
I have done that job and found it a pain. I bought a 3 piece fork type splitter off eBay cheap and used the largest from memory and it has a long screw in handle. You could try a pry bar with an assistant to try and lever the joint while you hit it with the splitter.
29th Dec 2016 2:49am |
Here goes!!
29th Dec 2016 12:01pm |
