Home > Technical (L322) > Can't open car |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7760 |
Key ?
31st Dec 2016 5:47pm |
mr_spock Member Since: 07 Apr 2016 Location: Welwyn, Hertfordshire Posts: 311 |
Mine does that very occasionally. I believe the sensor is in the driver's A pillar, so hold the key up neat the window and see if that helps. Otherwise it may have gone out of sync. In which case, open the door with the key and resync it. Instructions in the wiki I think. |
31st Dec 2016 6:09pm |
Skip720 Member Since: 12 Jun 2016 Location: Wakefield Posts: 32 |
The key just turns in the lock but doesn't open |
31st Dec 2016 6:15pm |
Alistair it's a nearly new battery only been on four months |
31st Dec 2016 6:17pm |
Ah, that's a problem. Mine did that, but luckily the remote fob worked so I could fix it. Clearly when you get it open you MUST fix the physical locking/unlocking issue!
31st Dec 2016 6:22pm |
Do you have a spare key to try as a remote ? |
31st Dec 2016 6:23pm |
I have a spare key but it has no buttons and just turns like the master. Does anybody know a good car locksmith in Wakefield |
31st Dec 2016 6:26pm |
Thanks guys I appreciate your help |
31st Dec 2016 6:28pm |
Are you on the AA or RAC ? they can sometimes help ? |
31st Dec 2016 6:29pm |
Are you sure the car isn't just flat?
31st Dec 2016 6:46pm |
I have a tow socket, do you know how I would charge from that? |
31st Dec 2016 6:53pm |
Do you have twin electrics ?
31st Dec 2016 6:55pm |
If as Alistair says the voltage is low across the 3/4 terminals you can make up a cheap adapter using an old 12s plug and some wire and terminal blocks to those terminals in the plug, then connect this to your charger.
31st Dec 2016 7:07pm |
I only have single socket. Would that be different? |
31st Dec 2016 7:14pm |
