Home > Maintenance & Mods (L322) > Filler cap retainer strap replacement
Page 3 of 3 <123
trickymickey
United Kingdom 2002 Range Rover HSE 4.4 V8 Adriatic Blue
I did mine this afternoon and used 17amp wire , perfect for the job ! ......and black.
Post #325884 3rd May 2015 10:50pm
rar110
I'm thinking about doing a similar repair, except using bunjee or shock cord. I'll loop one end around and under the top bolt head, fixing the flap hinge to the body, and will feed the cord through the cap hole and tie a knot at the other end.
Anyone done this repair using cord? ______________________________
Post #421542 7th Jan 2017 7:19am
holidaychicken
I bought some rubber o ring material off eBay , if you slide one end into the notched cut out it holds really well and the end that fits into the cap I heated up with a lighter and pushed it into the cap so it splays out inside and then can't come back out. I can look up what I used
Post #421700 8th Jan 2017 4:01am
rar110
Yes please. Was it a big oring that you cut? ______________________________
Post #421701 8th Jan 2017 4:12am
holidaychicken
I bought a 1 metre length of 5 mm, it is material that is designed for making your own O ring and gluing together
http://www.ebay.co.uk/itm/Metric-Black-Rub...0281715167
I'll take a photo of mine later when i am not being used as Dad's taxi service
Post #421718 8th Jan 2017 10:58am
rar110
Thanks, yes please. ______________________________
Post #421817 8th Jan 2017 10:13pm
holidaychicken
Pic attached below, it is a bit dark and rainy here.
The rubber looks like it might be starting to crack but it is still holding fine and at 3 for a metre and 2 minutes to fit it might be a solution for somebody Smile
Post #422006 9th Jan 2017 11:08pm
rar110
Thanks. ______________________________
Post #422010 9th Jan 2017 11:48pm
nino_nino
Hello,
rar110 you can use old O ring from oil filter it is 3.4 mm thick ,so .4mm thicker then the original and is 24.5cm long when cut.
material is some kind of silicon rubber , very tough and free. Very Happy
Post #422065 10th Jan 2017 3:54pm
supershuttle
England 2010 Range Rover Autobiography 5.0 SC V8 Ipanema Sand
In my mod the drive belt eventually perishes with the petrol fumes, might be OK on a diesel - don't know. So I now use a part of a lanyard that half the working population seem to have round their neck with passes or some such dangling on the end. Its cloth - so far so good.
I've still never actually dropped the filler cap and I'm at the pump at least once a week, its obviously waiting for the day when I don't have a retainer on it Rolling with laughter Geoff
Post #422068 10th Jan 2017 4:12pm
Nomad
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Zermatt Silver
Stupid question of the day: Does the old retainer just pull out of the top of the filler cap? I don't want to leave anything stuck inside. 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #422076 10th Jan 2017 5:20pm
rar110
The plastic cover of the fuel cap pops off. Under the top is a spring. Under that is the strap. I pushed it out using a screw driver. ______________________________
Post #422180 11th Jan 2017 12:47pm
Nomad
Thanks Bow down 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #422212 11th Jan 2017 5:13pm
Page 3 of 3 <123
Site Copyright © 2006-2018 Futuranet Ltd & Martin Lewis
