Home > Technical (L322) > Xenon lights dim
Jase71
United Kingdom 2017 Range Rover Vogue TDV6 Santorini Black
Xenon lights dim
Anyone else have dim head lights? I thought xenons were supposed to be quite good? Could it also be my car (56 plate) with 105k miles may have time expired bulbs?
Before I go out and replace both xenon bulbs, any thoughts? Looks like they are Phillips D1S...
Brand new battery and lights aligned 3 times already!
Post #421976 9th Jan 2017 9:06pm
Jase71
Eurocarparts say new bulb is D3S but the bulb in the car is D1S...have they updated?
Post #421979 9th Jan 2017 9:19pm
steveball
United Kingdom 2010 Range Rover Vogue SE TDV8 Bournville
I use the Osram bulb finder, which I have found accurate.
https://am-application.osram.info/en
According to this:
- Up to MY 2006 = D2S
- MY 2007-2009 = D1S
- MY 2010- = D3S
This sort of bulb is expensive to buy from Euro Car Parts, Halfords etc. I recently purchased some cheap Chinese imports via eBay, for about £20 the pair, which appear to be working fine. Current: 2010 Range Rover L322
Vogue SE, TDV8 3.6, Bournville
Now gone: 2002 Range Rover L322
Vogue, TD6, Giverney Green
Post #421983 9th Jan 2017 9:31pm
so much cheaper from ebay and you now have the opportunity to get some 'whiter' 6000k bulbs...
Post #421984 9th Jan 2017 9:36pm
Jase71
Thanks guys. Hmm the light ratings are quite confusing...
Do they dim with age?
Post #421988 9th Jan 2017 9:55pm
steveball
They definitely change colour with age, tending towards a lower colour temperature - more yellow and less white/blue. Not sure whether they also get dimmer, but halogen bulbs definitely do suffer with age and I had assumed that these must have something similar going on.
Google consensus is that they do get dimmer with age, so it must be true Laughing Current: 2010 Range Rover L322
Post #421990 9th Jan 2017 10:02pm
Jase71
Laughing Laughing
I think I'll just change them
Are they easy to change in situ? Haven't been able to find instructions anyway without removing the entire light assy.
Thanks in advance!
Post #421995 9th Jan 2017 10:22pm
steveball
Trivial 2 minute job on MY 2010+
Does not look as though its any harder on earlier cars.... No need to remove the light fitting. The following from p2400 of the workshop manual for MY 2006-2009
Post #421997 9th Jan 2017 10:44pm
Jase71
Many thanks Steveball Bow down
That removable clamping ring looks unusual, I assume that acts like a bush/holder for the bulb?
Looks pretty tight to get access on one side but hopefully I'll be okay!
Post #422001 9th Jan 2017 11:01pm
Jase71
Do replacements come as a complete unit with the ballast/igniter?
Post #422004 9th Jan 2017 11:05pm
GDM
United Kingdom 2006 Range Rover Vogue Td6 Zambezi Silver
Re: Xenon lights dim
Ours is the same:-
http://www.fullfatrr.com/forum/topic41099.html
Post #422012 9th Jan 2017 11:56pm
Jase71
Going to replace yours GDM? I'm going for D1S Phillips ones.
Post #422014 10th Jan 2017 12:03am
GDM
Most probably. Ours is a 55 plate, so it looks to have the D2S type. These seem to be just replacement bulbs without the driver unit, so they are a lot cheaper. There are some good deals on E-bay but not sure about the quality. Also, not sure what rating to go for.
Does yours have working cornering lights?
Post #422015 10th Jan 2017 12:18am
supershuttle
I must admit that, although mine is a newer car taking D3Ss, I just bought some Osram Unlimited to replace the eBay ones as they are a bit brighter. The eBay ones were as bright as the originals but not as bright as the Osrams - as i get older any increase in brightness is welcome.
The eBay ones cost less that £40 (although one was faulty on receipt it was replaced without quibble) the Osrams cost £140 but are a bit brighter so to me worth the cost of a tank of fuel (and a bit) Very Happy
Unlike some I am not interested in the colour of the headlamps (as perceived by others) but rather the light they put on the road for me Shocked Geoff
Post #422035 10th Jan 2017 10:48am
Jase71
Many thanks to Steveball; just changed my xenons over and the instructions worked a treat! Had them done in 10 mins. One side was trickier than the other and I was most worried about touching the glass or damaging during seating of the bulbs but all went really well! Tonight will be the test to see if they are brighter. They certainly appear much brighter just looking at them (much whiter light).
GDM: Doesn't look like I have cornering bulb as mine has chrome blank in place of bulb.
Post #422048 10th Jan 2017 12:13pm
