Home > Technical (L322) > Xenon lights dim |
Jase71 Member Since: 13 Apr 2016 Location: Portsmouth Posts: 479 |
Eurocarparts say new bulb is D3S but the bulb in the car is D1S...have they updated? |
9th Jan 2017 9:19pm |
steveball Member Since: 09 Jun 2011 Location: Corsham, UK Posts: 208 |
I use the Osram bulb finder, which I have found accurate.
9th Jan 2017 9:31pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34935 |
so much cheaper from ebay and you now have the opportunity to get some 'whiter' 6000k bulbs... |
9th Jan 2017 9:36pm |
Thanks guys. Hmm the light ratings are quite confusing...
9th Jan 2017 9:55pm |
They definitely change colour with age, tending towards a lower colour temperature - more yellow and less white/blue. Not sure whether they also get dimmer, but halogen bulbs definitely do suffer with age and I had assumed that these must have something similar going on.
9th Jan 2017 10:02pm |
9th Jan 2017 10:22pm |
Trivial 2 minute job on MY 2010+
9th Jan 2017 10:44pm |
Many thanks Steveball
9th Jan 2017 11:01pm |
Do replacements come as a complete unit with the ballast/igniter? |
9th Jan 2017 11:05pm |
GDM Member Since: 21 Nov 2016 Location: West Sussex Posts: 165 |
Ours is the same:- http://www.fullfatrr.com/forum/topic41099.html |
9th Jan 2017 11:56pm |
Going to replace yours GDM? I'm going for D1S Phillips ones. |
10th Jan 2017 12:03am |
Most probably. Ours is a 55 plate, so it looks to have the D2S type. These seem to be just replacement bulbs without the driver unit, so they are a lot cheaper. There are some good deals on E-bay but not sure about the quality. Also, not sure what rating to go for.
10th Jan 2017 12:18am |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3654 |
I must admit that, although mine is a newer car taking D3Ss, I just bought some Osram Unlimited to replace the eBay ones as they are a bit brighter. The eBay ones were as bright as the originals but not as bright as the Osrams - as i get older any increase in brightness is welcome.
10th Jan 2017 10:48am |
Many thanks to Steveball; just changed my xenons over and the instructions worked a treat! Had them done in 10 mins. One side was trickier than the other and I was most worried about touching the glass or damaging during seating of the bulbs but all went really well! Tonight will be the test to see if they are brighter. They certainly appear much brighter just looking at them (much whiter light).
10th Jan 2017 12:13pm |
