Home > Maintenance & Mods (L322) > Different Canbus Systems?
Danwilderspin
Hi All,
I am attempting a couple of big mods on my MY02 l322 v8.
I purchased the deployable side step kit for >06 but knew the it would be some work to make it work. After asking around about can bus someone said there are different languages of can bus. so these may differ.
In my head I was going to rein the loom and give it a go.
I parked the idea for a bit as my new project started to come together - the BMW NBT satnav mod.
Now they claim that this works on MY02 >MY09.
You have to tap into the bus and the can bus for the to work and it get all the check control messages from the can bus.
Also I know the last of the BMW 4.4 v8 got the new instrument cluster.
With all this in mind would it be likely they use the same can bus system? I would find it strange they redesigned it for just 3 years. What I would have thought is they tart up some of the pieces then in 2010 they did their own redesign of the network ahead of the l405?
What are peoples thoughts?
If this is the case then the steps may not be as hard...
Post #422540 13th Jan 2017 10:56am
andygts
United Kingdom 2013 Range Rover Autobiography SDV8 Luxor
Compare the screen grabs, they provide the answers you need, the steps use the medium speed can
Older BMW era can bus
Newer Ford/JLR
[/b] Current
2001 Porsche 911 Turbo
_____________________________________
Previous
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #422619 13th Jan 2017 7:19pm
Danwilderspin
thanks - are you 100% sure the use medium? the high speed looks the same thought it may use that as it incorporates the drive train?
Post #422641 13th Jan 2017 10:41pm
Danwilderspin
sorry to not let this drop - it looks like the conversions are done in the dash - is it possible to fit an 05 4.4 dash into an 02?
Post #426987 9th Feb 2017 1:05am
alistairh
Resurrection of this thread as I'm planning the same thing.. any further forward with this dan? Ready to order a set and I've seen them on older fattys so it is possible..Just a matter of how to? Ta
Post #434843 13th Apr 2017 9:51pm
Danwilderspin
Hi alistair - not had a chance yet tbh still trying to finish my nbt retrofit which I started then it will be boating season so will be a while... I was looking at possibly using timers to deliver power to the steps manually to begin with and have then on manual up and down and go from there...
Post #434852 13th Apr 2017 11:17pm
alistairh
Very intrested in this and determined now. Look forward to your updates dan. Thumbs Up
Post #434854 13th Apr 2017 11:30pm
