Home > Technical (L322) > All The Amigos
Triarii
United Kingdom 2017 Range Rover Autobiography SDV8 Corris Grey
All The Amigos
Just over 6 weeks since the fuel pump went on the M42 (outside lane whilst making reasonable progress!) I've now got all the warnings (HDC, TC, Special Progs, Suspension lowered, reduced gears etc). Had come on a few times recently but a restart saw them disappear. Luckily this time I was only 1.5 miles from home so limped back at c.8mph (hurray for rush hour congestion). Sounded like it was in 1st and low ratio - 2500rpm to do 8mph!
Off to the garage on the 3rd....... 17 MY Corris Grey 4.4 VAB
Silver MB R231 SL350
Post #420055 29th Dec 2016 7:14pm
Triarii
Garage (Guy Salmon) first though it was a wiring fault, then the HP fuel pump. They've still not diagnosed it, after 8 working days....... Rolling Eyes 17 MY Corris Grey 4.4 VAB
Post #422767 14th Jan 2017 8:08pm
forrey
Canada 2009 Range Rover Supercharged 4.2 SC V8 Java Black
is that guy slam on in croydon ? if it is take it somewhere else ! they are stupid monkey Censored ,they had a disco 2 of mine for a week and still could not work it out ..in the end was a loose alternator wire ... and the Censored then left a spanner in the engine bay and luckily it never got stuck in anything...bottom line go to guildford instead..they are much better Thumbs Up
Post #422777 14th Jan 2017 9:51pm
Triarii
Bristol......day 9 starts tomorrow...... Shocked 17 MY Corris Grey 4.4 VAB
Post #422921 15th Jan 2017 6:25pm
RR2008HSE
When you get a whole bunch of warnings all at once, my guesses would be: battery, alternator, Mechanic didn't hook something back up or reset something from last time.
Post #422959 15th Jan 2017 9:18pm
Triarii
HP fuel pump apparently. c£2300 to fix but possibly £7000 for a wider fix (awaiting the explanation anout that - seems to be relatrd to doing more than flushing). Found metal particles in fuel filter. Does this sound right? Also, given the in-tank pump failed 6 weeks ago, are they linked? 17 MY Corris Grey 4.4 VAB
Post #423486 18th Jan 2017 1:10pm
zarnd
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Bonatti Grey
Sounds like pump and injectors may need replacing which could explain the costs Alex
2018 Skoda Kodiaq vRS
2009 Caterham Supersport Race car
2007 M5 Touring
2005 Range Rover Vogue SE Supercharged
2004 SL55 AMG
Post #423496 18th Jan 2017 2:18pm
Triarii
The failed in-tank pump Censored up the HP pump. To be sure of removing all bits from the system its the expensive option. Means rebuild of HP fuel side using new components. Bloody thing had better work well from now on. Big Cry 17 MY Corris Grey 4.4 VAB
Post #423806 19th Jan 2017 6:26pm
