Home > Technical (L322) > buzzing, resonance,vibration |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34918 |
back in november 2016 i had the secondary turbo drain valve fitted and some deployable steps at the same time.... after collecting my westie a noticed on idle a buzzing/resonance/vibration coming mainly from the steering wheel, drivers seat and the cubby box on the centre console, this increased in intensity when the revs went to around 1000rpm..when driving this problem isn't apparent..
17th Jan 2017 12:24pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3676 |
You are lucky to have a son who is a master mechanic with access to a 4 poster .
17th Jan 2017 1:08pm |
17th Jan 2017 1:09pm |
proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452 |
Stan,
17th Jan 2017 2:38pm |
Mark, the dealer and my son checked the steps and i had them in and out and actually stood on them thinking that some weight would make a difference ...we havnt taken the steps off though..
17th Jan 2017 2:49pm |
driveshaft not re-aligned as it was before ?? Regards
17th Jan 2017 3:09pm |
yep it was ok, double checked by my son ..it was freshly marked/scored .. |
17th Jan 2017 3:12pm |
the vacuum on the engine mounts was checked and is ok Chris.. |
17th Jan 2017 3:29pm |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
Hi stan. You know the problems of the td6, as regards resonance, vibration. I have found, that it occurs mostly in access mode, or if moving up to standard height.
17th Jan 2017 3:33pm |
Do you get exactly the same feelings if you sit in other seats?
17th Jan 2017 3:38pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1341 |
Having googled L322 vibration I see there are lots of examples.
17th Jan 2017 4:02pm |
@greg, tried in all three height modes and all software up to date..
17th Jan 2017 4:11pm |
RP123 Member Since: 06 Jul 2014 Location: Highlands Posts: 187 |
Hi Stan,
17th Jan 2017 4:54pm |
thanks simon, the exhaust,heat shield and exhaust rubbers were checked ok..
17th Jan 2017 5:01pm |
