Home > Technical (L322) > buzzing, resonance,vibration |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34925 |
this is only on idle or increase of revs to around 1000rpm when it gets even worse, again when not moving Graeme...
17th Jan 2017 8:49pm |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2312 |
Mine's vibration only occurred whilst moving because that was when the tyres caused panels to vibrate. My thought was that the engine vibration could be causing something else to reverberate so worth checking that the pipes are properly spread by the (IIRC) 2 plastic clips, but perhaps some other pipes might be vibrating. The pipes from the ABS modulator are obscured below the transfer case ecu so can easily be overlooked. |
18th Jan 2017 5:08am |
we checked the pipes and they were ok Graeme , the consensus now is its somehow related to the engine as the engine block is vibrating/buzzing.. |
18th Jan 2017 10:09am |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2215 |
Stan what happens above 1000 rpm also is this in neutral or in d but not moving? |
18th Jan 2017 8:43pm |
Dave 67 Member Since: 11 Dec 2016 Location: Oxfordshire Posts: 34 |
Could it be viscous fan related or something in the torque converter? 2004 4.4V8 Vogue
18th Jan 2017 8:57pm |
Can you hear the vibration under the car? There is nothing that can't be fixed with a hammer😜😜
18th Jan 2017 8:58pm |
Idea.....
18th Jan 2017 9:00pm |
@sandy, over 1000rpm it disappears whether in neutral or drive...
18th Jan 2017 9:36pm |
does anyone know if the idle can be adjusted ? |
18th Jan 2017 10:02pm |
proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452 |
possible from altering the engine map, but no aware of anything that could be done from otherwise. Regards
18th Jan 2017 10:24pm |
no screw to turn then Mark.... |
18th Jan 2017 10:28pm |
Regards
18th Jan 2017 10:43pm |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1328 |
Ah, those were the days.........adjusting the mixture and idle screws . 2017 4.4 SDV8 Autobiography 2012 4.4 TDV8 Westminster - Gone, but not forgotten |
18th Jan 2017 11:59pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Assuming that you haven't been to the Ann Summers Shop, , You're complaining of a buzzing or is it a vibration?
19th Jan 2017 1:03am |
