Home > Technical (L322) > buzzing, resonance,vibration
Page 3 of 6 <123456>
Problems with NVH are usually down to mass of the object and resonance through it, you have changed the mass by adding the steps, standing on them will stop them vibrating but it is usually the weakest part that will vibrate so it maybe worth following the earlier advice to remove them and see if that helps, you seem to have covered everything else...
If a mechanic has dislodged or upset something doing the work on the engine, you would think a fault would show up but I'm not up on these "devils fuel" FF's..... Thumbs Up Pete
Post #423634 19th Jan 2017 1:27am
@paul, i thought injectors as well hence the shell nitro and diesel additive ...when moving the westie runs perfect , i even took it up to 130mph whilst on a break abroad...
@pete,the engine runs ok but 'feels' like its running slightly faster than i remember before this work was done ...
i think its going to be a process of elimination so when i can i'll take the steps off and then go from there..
thanks chaps.... Wink
Post #423650 19th Jan 2017 8:43am
miggit
In my experience the only injector cleaner that worked was Ultrasonic..... on a test rig, at the Bosch service centre Whistle What sort of distance has your Bus covered? If it's a high miler then a proper clean might be the only way to eliminate them... Think I'd be dropping the steps first Whistle Yesterday I couldn't spell Engineer... Today I are one!
Post #423667 19th Jan 2017 9:51am
around 72k paul..
its weird that it only started after the work was done.....if you put your hand on top of the engine you can also feel it there ...
i wonder if the iidtool would come up with any live values that might explain this..
Post #423671 19th Jan 2017 9:58am
miggit
Possibly... live data on the injectors gives an indication, they should all be roughly the same.. And while 72K is a low milage, you are getting into dirty injector regions Rolling Eyes
It might be worth talking to a Bosch Service Centre... they will be a lot less than the stealers, and they have the correct equipment to diagnose and sort.. And my local charges £60 an hour Whistle Yesterday I couldn't spell Engineer... Today I are one!
Post #423678 19th Jan 2017 10:13am
thanks paul...it beggers belief that i've more sense from the forum than the dealer....
Post #423679 19th Jan 2017 10:16am
miggit
Whistle Count yourself lucky that it's a Range Rover.... if it was a Mercedes you'd be Banging Head Banging Head Big Cry by now Laughing
I was looking at Bosch Service Centres in your neck of the woods.. but their site is fubar'd Shocked
Looks like Bristol is your nearest Sad But that's not to say that there isn't one on your doorstep... I just can't find it Thud Yesterday I couldn't spell Engineer... Today I are one!
Post #423683 19th Jan 2017 10:27am
proser
We are here to help each other, the dealer is just there to make money and they are not doing that with you currently. Whistle Regards
Mark
2012 Westminster
GONE - 2007 Java Black FF Vogue, with Ivory interior
Post #423686 19th Jan 2017 10:33am
miggit
A dealer is only as good as his Testbook Whistle
If it doesn't compute then they are lost Laughing Yesterday I couldn't spell Engineer... Today I are one!
Post #423689 19th Jan 2017 10:36am
re ''Bosch Service Centres'' theres a couple in swindon, what more can they do that the dealer can Paul..
also i must take into consideration that this problem is being dealt by a warranty claim..
Post #423692 19th Jan 2017 10:47am
miggit
For a kick off they have test rigs for the injectors... and cleaners too! And bearing in mind that Bosch supplied the injectors to start with, LR will be using Bosch software to operate them! Plus they will have flow and pressure test equipment that the stealers wont have access to, or any idea how to use Laughing
It would be worth a telephone conversation... after all if it was a gearbox fault who would you trust to sort it.. stealers or a specialist like RRPhil? The stealers will not be in to replacing the injectors, they will be doing their very best to avoid this Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #423696 19th Jan 2017 10:55am
proser
Here's a sample of the RPM from mine at idle, if you need to compare
 Regards
Mark
2012 Westminster
Post #423698 19th Jan 2017 10:58am
valid point paul.... Thumbs Up
i'll go and compare mine now mark.. Thumbs Up
Post #423702 19th Jan 2017 11:04am
Baltic Blue
I hope you get this sorted soon Stan, I am getting paranoid.... listening for the slightest rattle, vibration, noise etc every time I go out, but thankfully everything seems fine on mine following the turbo drain mod work.
Best wishes
Post #423705 19th Jan 2017 11:17am
cheers mike, your dealer obviously did the job properly... Wink
@mark, my rpm is pretty much the same as yours,
Post #423711 19th Jan 2017 11:50am
