Home > Technical (L322) > 4.4tdv8 plastic intake manifold
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
anyone know of any splitting like the tdv6s one are prone too? Cheers
James
Post #424042 20th Jan 2017 11:05pm
JST
found one: http://www.fullfatrr.com/forum/post424043.html#424043 Cheers
James
Post #424044 20th Jan 2017 11:15pm
Ritchey
Hi James,
I bought a 2011 4.4 TDV8 in December last year, had a loss of power couple of days ago followed by performance restriction. It seems I've got a cracked inlet manifold as there is clearly air escaping the left hand side as you face from the front of the car.
I took out 12months AA warranty from the dealer, which I'm hopeful will cover the repair costs.
Spoke with the dealer today and he suggests the likelihood is they'll only authorise one half of the manifold, he said it would be worthwhile getting the other side done and the cam belt at the same time at my own cost. (I'd be getting the second half and a cam belt change for roughly the cost of the cam belt change i'd need in the not too distant anyway).
Rich
Post #435044 16th Apr 2017 11:44am
stu
does your engine not have a timing chain? Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #435057 16th Apr 2017 12:57pm
Ritchey
Sorry yes timing chain, think they're recommended for change at around 105,000 miles. I'm on 83k at the minute and would likely hit 100k in the next 12 months.
Post #435058 16th Apr 2017 1:04pm
stu
Forget it! A chain should never really go wrong, maybe the tensioner eventually. Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #435060 16th Apr 2017 1:28pm
GraemeS
I suspect the belt change interval is for the accessory belts.
Post #435130 16th Apr 2017 10:10pm
Buz1500
United Kingdom 2019 Range Rover Autobiography SDV8 Carpathian Grey
Mine split last year whilst on holiday in France. Had to get a replacement fitted at the LR dealer in Nantes
Post #435153 17th Apr 2017 10:02am
No cam belt, only belts are the 2 aux belts at the front. As said at some point the chain tensioner might need changing but I doubt that would be anything like 100k more like 200k.
The aux drive belts are meant to be fitted for life, but as with everything they should be changed as a matter of course and the condition of the pulleys and tensioners checked. I can't see how changing the intake manifold on the top of the engine and changing the belts on the front of the engine have any relation in terms of disassembly. The top manifold is pretty easy to remove and doesn't involve taking the fan and fan shroud out which if I remember the aux belt requires. There is nothing that can't be fixed with a hammer😜😜
Post #435159 17th Apr 2017 11:15am
Ritchey
Thank you for all the replies and information, very much appreciated.
Post #435160 17th Apr 2017 11:17am
Ritchey
Update is that it is one of the 4 rubber boots that has split, unfortunately not covered by my warranty but about £100 for the 4 boots and £150 in labour. So it could've been worse.
Dealer had mistakenly assumed I was in a V6 RRSport when I'd called about the issue, apparently intake manifold issues are far more common place on them. He said straight away this was running a timing chain and that wouldn't need changing.
Now just got to wait for the back ordered parts......
Post #435549 21st Apr 2017 2:03pm
Baltic Blue
This Bulletin details the problem.
Mine was fixed by replacement under Approved warranty. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #435551 21st Apr 2017 2:24pm
Ritchey
Thanks Baltic, that's a huge help.
Warranty cover was a 12 month cover policy via AA bought at same time as the car.
I will forward this onto the dealer who provided the vehicle, if nothing else but to ensure the updated parts are ordered.
Disappointing this didn't happen prior to me buying whilst the car was still under manufacturers warranty!
Post #435559 21st Apr 2017 3:41pm
