Home > Technical (L322) > 4.4tdv8 plastic intake manifold |
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 428 |
anyone know of any splitting like the tdv6s one are prone too? Cheers
20th Jan 2017 11:05pm |
found one: http://www.fullfatrr.com/forum/post424043.html#424043 Cheers
20th Jan 2017 11:15pm |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 |
does your engine not have a timing chain? Current: TDV8 (3.6) RRS HSE
16th Apr 2017 12:57pm |
Ritchey Member Since: 16 Apr 2017 Location: Chester Posts: 5 |
Sorry yes timing chain, think they're recommended for change at around 105,000 miles. I'm on 83k at the minute and would likely hit 100k in the next 12 months. |
16th Apr 2017 1:04pm |
Forget it! A chain should never really go wrong, maybe the tensioner eventually. Current: TDV8 (3.6) RRS HSE
16th Apr 2017 1:28pm |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2308 |
I suspect the belt change interval is for the accessory belts. |
16th Apr 2017 10:10pm |
Buz1500 Member Since: 05 Sep 2011 Location: Cumbria Posts: 354 |
Mine split last year whilst on holiday in France. Had to get a replacement fitted at the LR dealer in Nantes |
17th Apr 2017 10:02am |
No cam belt, only belts are the 2 aux belts at the front. As said at some point the chain tensioner might need changing but I doubt that would be anything like 100k more like 200k.
17th Apr 2017 11:15am |
Thank you for all the replies and information, very much appreciated. |
17th Apr 2017 11:17am |
Update is that it is one of the 4 rubber boots that has split, unfortunately not covered by my warranty but about £100 for the 4 boots and £150 in labour. So it could've been worse.
21st Apr 2017 2:03pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3674 |
21st Apr 2017 2:24pm |
Thanks Baltic, that's a huge help.
21st Apr 2017 3:41pm |
