Home > Technical (L322) > Advice / thoughts please on cause of Limp Mode
cgarside
United Kingdom 2008 Range Rover Vogue TDV8 Stornoway Grey
After driving for 15 mins the Range Rover (08 TDV8 Vogue) went into what I would describe as Limp Mode as we accelerated (gently, note!) onto the M65. We returned home with the engine in limp mode OK. When in limp mode the engine would not go above 2000rpm. No lights on dash (i.e. No CEL) showed. With the car home iand having been left for a couple of hours, it restarted fine and engine would go above 2000rpm. I took it out for a run and everything appeared fine.
So, I'm puzzled as to what has caused this (note, I have not had the chance to check if any fault codes exist)
Anyone had a similar problem ?
Chris 08 Range Rover TDV8 Vogue
Post #429308 26th Feb 2017 7:13pm
Roystonh
Had this with mine and it turned out to be a full DPF - had a new one done under warranty. Don't know if that helps? 2005 L322 Vogue Gold gone
2006 L322 Vogue Black gone
2011 L322 Vogue Silver gone
2011 L322 Autobiography Black gone
2015 L405 Autobiography LWB Black gone
2019 L405 P400e Range Rover Autobiography LWB Eiger grey / black roof gone
2001 P38a 30th Anniversary Wimbledon Green gone
2019 L405 P525 Autobiography LWB British Racing Green
Post #429310 26th Feb 2017 7:19pm
Boydonegood
United Kingdom 2004 Range Rover Vogue Td6 Ipanema Sand
Exact same on my TD6. Turned out to be bad fuel and fuel filter. Drained tank, changed filter. All back to normal. Accept, some days your the pigeon, some days your the statue!
Post #429311 26th Feb 2017 7:22pm
cgarside
Ironically, we were actually setting out on a 70 mile run to get everything warm and cleared out since the car has really only had short journey (less that 11 miles) recently. Am I right in assuming that a long run will clear the DPF or will it need changing?
Post #429313 26th Feb 2017 7:35pm
cass
United Kingdom 2014 Range Rover Autobiography SDV8 Causeway Grey
possibly split intercooler hose - common problem
Post #429314 26th Feb 2017 7:38pm
Intercooler hoses is a distinct possibility on a 3.6 TDV8 - usually hard acceleration though & a message along the lines of Special Programs Off
Post #429326 26th Feb 2017 9:18pm
kbald
I didnt think the 2008 diesels had dpf filters and they were added to later year models! Would check the hoses but they are usually athrow loads of black smoke out of the back at the same time.
Post #429328 26th Feb 2017 9:24pm
MY2008s don't have DPF. My money would be on a split hose. Got - 2017 SDV8 Autobiography in Loire Blue
Post #429339 26th Feb 2017 10:40pm
cgarside
When the performance dropped off, I checked exhaust and no signs of smoke. Just very limited performance. The five mile journey to get home was done without drama, just went very slowly.
When I restarted the car after a couple of hours and went for a run, performance was back to normal. Hard acceleration was accomplished without any signs of exhaust smoke.
I briefly checked the turbo hoses and could not see any immediate signs of rupture.
I will check again tomorrow and report back when I get fault code readings
Post #429347 26th Feb 2017 11:41pm
rar110
You might need to take the hoses off to see a crack. That has been some people's experience. ______________________________
Post #429349 26th Feb 2017 11:47pm
cgarside
Checked hoses and no sign of splits or leaks and as the car has driven fine for the last week or so I have discounted this as the root cause of the problem.
Since this first occurred I have had the RR to my local garage and no fault codes have been registered.
Driving the car today, I had the same thing happen again, only this time I got a dash message stating 'Special Programmes Fault'. Engine power was cut back and I pulled off the road to investigate further. On selecting the first special programme, I got a message on the central display stating 'Hill Decent Programme' fault.' I then selected normal drive mode and engine restarted fine and car behaved itself for the rest of the journey.
Given today's experience, my thoughts are
1. If Special Programmes have a fault but are not selected why would this manifest itself in a drop in engine power
2. If I have a problem with the Special Programmes functions, I would expect this to show in the LR specific OBD codes rather than the generic codes which is what I suspect my local garage were able to read.
Any thoughts / advice would be very welcome.
Regards
Post #430774 11th Mar 2017 10:41am
My money is also on the hoses.
Take off the top passenger side hose and have a look under the webbing that's where they go. 5min job then you will know. You cant normally see the split without removing the hose. Thumbs Up
Have a look at this to see where you should be looking
http://www.fullfatrr.com/forum/topic26843.html There is nothing that can't be fixed with a hammer😜😜
Post #430776 11th Mar 2017 11:22am
cass
Don't take the warning messages too literally as they are not always accurate.
The software can't always detect the exact fault so resorts to "flash random lights and messages until the owner panics" mode, in the hope of improving dealer profits.
Still sounds like a hose leak to me
Post #430795 11th Mar 2017 1:56pm
cgarside
OK, so I clearly didn't check the hoses properly.
Got home and followed NMJ's guide (thanks btw NMJ, this shows me what I hadn't done!). Took both upper hoses off and found N/S hose with a 60mm split under the protective sheath. O/S hose had no split, but was clearly ageing. Both will now be replaced and hopefully this will cure the problem.
However, when I removed both hoses, I found oil residue inside the hoses. Is this a sign the turbos need changing ?
Regards
Post #430822 11th Mar 2017 6:50pm
Oil in the pipes is pretty normal and nothing much to worry about Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #430838 11th Mar 2017 8:14pm
