Home > Maintenance & Mods (L322) > E-diff retrofit to MY12 4.4TDV8 L322 |
Giantlandyman Member Since: 25 Nov 2015 Location: Essex Posts: 800 |
Wow. Just wow.
27th Feb 2017 10:07pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7760 |
Indeed that's a serious retro-fit |
27th Feb 2017 11:14pm |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2308 |
I can supply the relevant part numbers etc.
27th Feb 2017 11:59pm |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
A great effort Graeme, that few of us would have been able to re-engineer like you have.
28th Feb 2017 7:56am |
The RRS has the same diff housing as the Discos but ratios would have to be checked. |
28th Feb 2017 8:52am |
Ta. Just curious. I've never been stuck and don't have a driveway like yours to justify one. It would be a very nice to have.
28th Feb 2017 9:16am |
The only time I've been stuck in the RR was when wedged amongst rocks in the mud whilst negotiating the track purporting to be the public road to access my home but the e-diff retrofit was well under way by that time anyway. |
28th Feb 2017 10:55am |
Ajmngn Member Since: 25 May 2021 Location: Gloucestershire Posts: 183 |
Graeme,
21st May 2023 9:49pm |
I had considered moving my CW&P to a diff out of a 4.2 SC because they were readily available. LR don't sell diff components such as the pinion crush spacer and although I was aware of a supplier in the USA, I couldn't be without my only vehicle while the diff conversion occurred. I had thought to replace only mine's side housing, leaving my pinion in-situ and hoping that the meshing could correctly set, but again I couldn't be without my vehicle. |
22nd May 2023 12:58pm |
Graeme, that’s interesting and thanks for the reply.
22nd May 2023 1:18pm |
This is the eDiff I’ve found. It’s from a 4.2SC. It’s the only photo provided but only £200 so seems a bargain. I can get a 4.4TDV8 open diff even cheaper and would then sell the one that comes off my car to hopefully recoup a few £££.
22nd May 2023 1:30pm |
The crown wheel from the open 4.4 diff will need to be transferred to the e-diff centre. The backlash will then have to be checked and adjusted by shims fitted behind the bearings if out of spec.
23rd May 2023 1:41pm |
