Home > Technical (L322) > Flat spot/hesitation at 1500-1700 rpm
Rob99
My westie seems to have developed a bit of a flat spot at around 1500-1700rpm. Some days its fine but has become more frequent recently.
When I accelerate its fine at first but then when I lift off at 1500-1700rpm I get a strange sort of wop wop warble sound (sorry I don't know how else to describe it... Whistle ) and a momentary loss of power. This only last a second or so then it picks up the revs fine as if nothing is wrong. It does also happen at the same rpm when I am driving at a steady speed.
I'm wondering whether it is an injector issue, engine map, EGR or turbo wastegate (really what I mean is I have no idea how to narrow it down Rolling Eyes ) It idles fine too. On a petrol I would say it was like a timing misfire but that won't apply to a diesel.
Any thoughts before I bung it in the dealers? I always like to go with some idea so I don't get fobbed off as a new fattie owner with "Oh that's normal Sir" Shocked 2017 4.4 SDV8 Autobiography
2012 4.4 TDV8 Westminster - Gone, but not forgotten
Post #434913 14th Apr 2017 5:18pm
GraemeC
United Kingdom 2007 Range Rover Vogue SE TDV8 Zermatt Silver
Check your top hoses for splits - very common problem and can cause similar symptoms Thumbs Up 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #434919 14th Apr 2017 5:51pm
Rob99
Good suggestion Graeme but top hoses were renewed a few months ago with another issue so unlikely to be them.
I could understand if it only happened when accelerating when the turbo pressure increases but it also happens when I am pootling along at a steady 70ish on the motorway.
Cheers 2017 4.4 SDV8 Autobiography
Post #434920 14th Apr 2017 5:59pm
GGDR
Got the same. Very very occasionally I'll put the foot down - and nothing
. Cheers, Greg
Post #434922 14th Apr 2017 6:23pm
anything like this Rob,
http://www.fullfatrr.com/forum/topic33589....tion+speed
or ,
http://www.fullfatrr.com/forum/topic38291....tion+speed ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #434927 14th Apr 2017 7:13pm
Rob99
Top man Stan Thumbs Up
Those threads do seem to describe the issue I am having, similar to the one you had at 80ish, and others too. Seems like a reasonably easy solution if it's a software update which the dealer can do easily. I will try and get hold of a copy of the TSB document for when I speak to them.
Must learn to use the search function more....... Rolling Eyes 2017 4.4 SDV8 Autobiography
Post #434942 14th Apr 2017 9:27pm
Rob99
Fattie in for MOT today so got the dealer to investigate the hesitation issue. Told them what I thought it was (thanks all for info) so they checked it all out, cleaned the MAP sensor, updated the PCM software and (touch virtual wood) it seems to have solved the issue, at least for the 20 miles or so I have done since picking it up.
Now that's jinxed it..... Shocked Shocked
. 2017 4.4 SDV8 Autobiography
Post #437191 5th May 2017 6:33pm
