Home > Off Topic > Any plumbers?
Andy
Any plumbers?
I want to put a tap in my internal garage. The en suite is directly above the garage and I was wondering if I could take a feed off of the cold water tap which runs under the floorboards.
Post #435157 17th Apr 2017 11:10am
i'm not a plumber but i got a feed of the cloakroom toilet/sink cold feed to supply my washing machine in the garage which is adjacent to the cloakroom so your idea sounds like a plan.... ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #435163 17th Apr 2017 11:22am
Andy
I did think about the downstairs toilet as it backs onto the garage. I thought the fall from upstairs might assist with pressure though.
Post #435165 17th Apr 2017 11:31am
I did pretty much the same thing Thumbs Up
It would depend whether the taps are fed from the tank or have incoming mains pressure - I thought that they were usually mains pressure.
Post #435166 17th Apr 2017 11:36am
It doesn't matter, the fall won't make a difference as the outlet tap you are fitting is where it is regardless so it's the fall from the header to there. If the downstairs wc is easiest then do that. Do you actually have a header tank for cold water in the loft, if not then all you cold water feeds will be mains pressure in any case so it will be irrelevant.
You should fit a check valve between the feed and the tap so as to prevent any back contamination from hoses etc fitted to the tap👍🏻 There is nothing that can't be fixed with a hammer😜😜
Post #435167 17th Apr 2017 11:39am
Andy
Yes, there is a header tank in the loft. I could take a feed off that I suppose?
Post #435172 17th Apr 2017 11:53am
Just take a feed from the most convenient place.
As NMJ says, if its tank fed, then its vertical drop that matters, the pipe routing has little effect.
Post #435174 17th Apr 2017 12:07pm
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
People watching so much porn on the internet is giving them an unhealthy and unrealistic expectation of how quickly they can get a plumber. letters not necessarily in the right order
Post #435178 17th Apr 2017 12:41pm
mpirie
^^ Rolling with laughter Rolling with laughter Rolling with laughter
Post #435179 17th Apr 2017 1:03pm
if you have a header then all your cold taps will be gravity fed apart from the kitchen tap probably. So just take the feed from the WC if that is the easiest. Thumbs Up
16mm drill through the wall and an outside tap kit from the plumbers merchant. You can get them as a pipe with a backplate flange on the end so you just have to drill it thorough the wall fit the tap with the supplied PTFE tape, vertical it up first, only then screw it to the wall otherwise the tap will end up Censored at an angle, then just pipe up the end in the WC. Comes as a kit with all the fittings you are likely to need in compression. If you have city plumbing near to you then they should stock them. There is nothing that can't be fixed with a hammer😜😜
Post #435210 17th Apr 2017 5:48pm
I put a tap in my garage and also a couple in the garden. I made sure there was a valve to turn it all off and that it can be drained completely, otherwise you may get frozen pipes.
Post #435212 17th Apr 2017 6:00pm
