Home > Maintenance & Mods (L322) > Wobbly wagon??? |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 |
Tyre pressure?
21st Apr 2017 9:01am |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 818 |
One of the hub nuts working loose.. ______________________________
21st Apr 2017 9:31am |
Rockyd31 Member Since: 17 Dec 2016 Location: Chesterfield Posts: 36 |
Thanks for the input guys.
21st Apr 2017 2:57pm |
Absolutely, jack up all the corners one after the other and check for free play.
21st Apr 2017 3:00pm |
Foulolron Member Since: 05 Aug 2015 Location: East Yorkshire Posts: 29 |
Have you checked the rear bushes - I went through two sets (genuine RR parts) in four years of ownership last time I had them replaced ended up having a new hub carrier fitted - as they got worse it started to feel "loose" at the back end |
21st Apr 2017 3:13pm |
Looks like a few things to try this weekend. Thanks all, I'll report back if I find the cause. |
21st Apr 2017 4:30pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3675 |
You could take it for an MOT and ask them to report any bush wear .
21st Apr 2017 4:54pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34916 |
i'd suggest a warped tyre or buckled wheel could be causing that.. ... - .- -.
21st Apr 2017 5:47pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3954 |
I would try replacing each wheel in turn with the spare to see if the problem goes away with a particular wheel change. |
21st Apr 2017 5:54pm |
Madyaker Member Since: 13 Apr 2015 Location: Wigan Posts: 39 |
+1 on the buckled wheel. sounds like the exact symptoms I had. |
22nd Apr 2017 11:07am |
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 |
Putting it is neutral will not eliminate the drive train - it all still spins around. Just driven by the road wheels rather than the engine |
25th Apr 2017 2:12pm |
Finally got this isolated to the rear left corner and has been confirmed today as a warped tyre making Stan the winner. Thanks for all the input guys Pirelli scorpions £194 each corner better than a blow out though... |
28th Apr 2017 4:33pm |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1227 |
Interesting. I had exactly the same issue last week. Steering was fine and not juddering, but the car felt a bit vague and the rear of the car wobbled side to side under 35 mph.
17th Mar 2018 3:16pm |
