Home > Maintenance & Mods (L322) > Wobbly wagon???
Rockyd31
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Java Black
Wobbly wagon???
Ok, random, but over the last month my SC has developed what can only be described as a wobble in the form of a mild side to side rock at low speed. The slower the speed to more movement, the faster the speed the faster but less severe (if that makes sense). So it seems to be speed related? Not really noticeable at a crawl but appears as you move through 10mph and continues up to about 50mph then disappears.
This is felt under both acceleration and at a constant speed (including with the box in neutral which would eliminate drive train?) but isn't noticeable under braking.
I have checked suspension height for level, conducted a visual check of the undercarriage, checked wheel nuts for torque with nothing untoward found and also have no warnings or check lights.
Before I send it to be looked at and spend a fortune for a garage to investigate has anyone experienced similar or got any sensible suggestions as to what this may be?
Post #435502 20th Apr 2017 9:45pm
Clivefog
Tyre pressure?
Flat spot on a tyre?
Post #435525 21st Apr 2017 9:01am
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
One of the hub nuts working loose.. ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #435531 21st Apr 2017 9:31am
Rockyd31
Thanks for the input guys.
Tyre pressures are 36 psi front 40 rear.
Tyres appear fine and free from flat spots.
Interesting thought about the hub nut, just need something high enough to jack the rear clear of the ground to check. I should feel play through the wheel correct? Then remove wheel for access and tighten if that's the case?
Post #435552 21st Apr 2017 2:57pm
UK Marine
Absolutely, jack up all the corners one after the other and check for free play.
Very doubtful that it will be the hub nuts but if it was me I would be checking everything to do with suspension, steering and hub nuts.
Good luck. ______________________________
Simon
Post #435553 21st Apr 2017 3:00pm
Foulolron
United Kingdom 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
Have you checked the rear bushes - I went through two sets (genuine RR parts) in four years of ownership last time I had them replaced ended up having a new hub carrier fitted - as they got worse it started to feel "loose" at the back end
Post #435554 21st Apr 2017 3:13pm
Rockyd31
Looks like a few things to try this weekend. Thanks all, I'll report back if I find the cause.
Post #435564 21st Apr 2017 4:30pm
Baltic Blue
You could take it for an MOT and ask them to report any bush wear .
Much easier to check when up on a ramp . G reg 2.5VM Vogue Portofino red 1991- 1999
Post #435566 21st Apr 2017 4:54pm
i'd suggest a warped tyre or buckled wheel could be causing that.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #435571 21st Apr 2017 5:47pm
I would try replacing each wheel in turn with the spare to see if the problem goes away with a particular wheel change.
Post #435572 21st Apr 2017 5:54pm
Madyaker
United Kingdom 2002 Range Rover Vogue 4.4 V8 Barolo Black
+1 on the buckled wheel. sounds like the exact symptoms I had.
Post #435605 22nd Apr 2017 11:07am
berkshirelad
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
Re: Wobbly wagon???
Putting it is neutral will not eliminate the drive train - it all still spins around. Just driven by the road wheels rather than the engine
Post #435861 25th Apr 2017 2:12pm
Rockyd31
Finally got this isolated to the rear left corner and has been confirmed today as a warped tyre making Stan the winner.
Thanks for all the input guys Thumbs Up
Pirelli scorpions £194 each corner Big Cry better than a blow out though...
Post #436261 28th Apr 2017 4:33pm
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
Interesting. I had exactly the same issue last week. Steering was fine and not juddering, but the car felt a bit vague and the rear of the car wobbled side to side under 35 mph.
Took it into a big chain tyre shop and explained I think I might have a damaged or warped tyre. They checked them all and said my front and rear suspension was damaged and needed new bushes and arms. They said they don't do suspension repairs and sent me on my way wobbly car and all.
Booked it into my trusty local garage who called me 2 hours later stating that my suspension was fine and that I have a badly warped rear nearside tyre. Popped a new tyre on and all is well.
Stupid tyre company though. Just goes to prove you can rarely trust anyone even in the profession. Had they done their job they would have got a new tyre order. In the end they charged nothing and had the car for an hour. Don't think I'll be using them again.
I think I might have damaged the inner sidewall on a pothole. Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #472942 17th Mar 2018 3:16pm
