Home > Technical (L322) > Steering column lock on 10MY+ |
FrankRizzo Member Since: 27 Aug 2012 Location: Frankfurt am Main Posts: 205 |
Do the late models with keyless start still have a steering column lock that engages when the motor is switched off? Or was this only on the models with a mechanical ignition? 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
20th May 2017 2:11pm |
Cheers, good point 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
20th May 2017 5:27pm |
Steve67 Member Since: 22 Nov 2016 Location: Essex Posts: 18 |
i'm sure they do. After switching off the engine if you wait until the the display goes off you can hear a mechanical noise as the lock engages. |
20th May 2017 6:30pm |
Freddie The Fish Member Since: 13 Apr 2017 Location: Bedfordshire Posts: 115 |
My 2011 has a lock after I turn off, no idea how it works though. |
20th May 2017 7:00pm |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2312 |
I disabled my MY12's steering lock, not trusting the electronics to determine if the vehicle was no longer in use after learning about a MY07 when its alternator failed and rapidly discharged the battery. Not key-less but it still locked the steering whilst the key was in the ignition switch in the ignition-on position. I can't see any advantage in having steering locks in modern vehicles. |
20th May 2017 9:35pm |
Unnecessary quote removed
21st May 2017 12:05am |
