Home > Technical (L322) > Lost all keys |
Dave 67 Member Since: 11 Dec 2016 Location: Oxfordshire Posts: 34 |
Or disconnect the props at the UJ's as they enter the diffs and let the handbrake off and it will roll, put it on a flat bed then take it to the dealers. 2004 4.4V8 Vogue
20th May 2017 2:21pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
Cheers, that's another option.
20th May 2017 2:38pm |
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 |
I would think best thing to do would be call breakdown company let them.grt it to dealers, already wasted £200 on non functioning key
20th May 2017 7:04pm |
NVB Member Since: 14 May 2017 Location: Essex Posts: 103 |
I've just ordered a new key from Land Rover. It came ready cut and programmed to my car. Just had to add it to the memory with the coding process as in my other post in here. Don't think he would need an original key to follow this process. RR History
20th May 2017 7:07pm |
He did try the dealer and they said they wanted the vehicle taken to them.
20th May 2017 7:13pm |
See here. http://www.fullfatrr.com/forum/topic42668.html
20th May 2017 7:51pm |
Thanks for the thread, i need to PM Dan, where are the stickys please ?
20th May 2017 9:21pm |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
If he needs to move the car in the meantime just lift the leather gaiter for the gear lever off and there is a mechanical override for the park brake under there but I can't see why it has to go to the stealers in the first place. 2008 MY Supercharged
21st May 2017 4:38am |
Thanks , I'm learning a lot with this thread, I'll call round his house later and get the vin and email it over to Dan at Duckworths asking what the procedure is.
21st May 2017 9:09am |
Ok, bit of an update- got a quote from Dan at £148 but key will still need to be programmed by a specialist or car taken to dealer.
30th May 2017 8:50pm |
And another update..
21st Aug 2017 8:01pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7762 |
As far as I know, the key needs to be paired to the car.
21st Aug 2017 8:30pm |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 799 |
good to know that his pain will benefit us all in the long run , I always thought a dealer sourced key would work form the get go but clearly not |
21st Aug 2017 10:33pm |
Cheers guys, this is made so much more difficult by the fact that the guy my friend chose to replace the key is a bit of a numpty.......
21st Aug 2017 11:26pm |
