Home > Wheels & Tyres > Change of rims - more rubber now! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34928 |
looks good mike ... - .- -.
31st May 2017 7:10am |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
Nice sidewall.
31st May 2017 9:35pm |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 |
What tyres you got fitted? Current: TDV8 (3.6) RRS HSE
31st May 2017 10:15pm |
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 |
Looks cool Alex
1st Jun 2017 10:16am |
Spooky Member Since: 03 Aug 2009 Location: Swindon, Wilts Posts: 183 |
They are 265/60-18 Yokohama Geolander A/T-S. At 110H, they're fully weight- and speed-rated for the FFRR, which keeps my insurers happy! Regards, Mick 'Bertha' - 2014 SDV8 Autobigraphy ' - ' ' |
1st Jun 2017 4:14pm |
Just a pattern I've never seen before.. Current: TDV8 (3.6) RRS HSE
1st Jun 2017 7:18pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2217 |
Good tyres Geolanders |
1st Jun 2017 8:34pm |
362bkr Member Since: 15 Oct 2014 Location: Devon Posts: 679 |
i genuinely believe the fat high profile tyre look will be "in" again in the future , maybe a while though. |
1st Jun 2017 8:48pm |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
G'day Mick
1st Jun 2017 9:49pm |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2312 |
MY10 has the 3.6 and twin piston floating calipers, same as used on the 3.0 D4 and the na 5.0 MY11/12 available in Oz so Compomotives fit. They are locally (for me) owner-certified legal modifications to replace the 6-pot Brembos on my 4.4 TDV8 because the na 5.0 has them as standard. |
1st Jun 2017 10:28pm |
None at all - fitted okay over the stock sliding calliper (as they also do with the 4-pot Brembo set-up). The rears were a LOT tighter - I actually had to wire brush the callipers a bit, to remove the built-up surface crud ... Regards, Mick 'Bertha' - 2014 SDV8 Autobigraphy ' - ' ' |
2nd Jun 2017 10:07pm |
Your comment about Compomotives on the rear being a tight fit is interesting because standard 18" D4 rims fit my MY12 rears with about 3mm clearance. |
2nd Jun 2017 10:22pm |
Strange! But then again, mine is a pre-pro model, so may have some slightly different parts to standard. Regards,
2nd Jun 2017 11:14pm |
Graeme, are you saying D4 calipers are suitable for the 4.4 L322, which allow compo 18's? Do the rotors need to be changed?
4th Jun 2017 12:39pm |
