Home > Maintenance & Mods (L322) > Rain somehow getting/sitting inside front passsanger door
horse86
United States 2014 Range Rover Autobiography 5.0 SC V8 Causeway Grey
This started happening recently as far as I know...but every time it rains somehow water gets caught and pools up inside my passenger door. Then when I open the door it comes splashing down the front door panel, speaker and gets some water on the carpet. Very frustrating. I don't want the interior to get wet or the electronics. It doesn't come in while iits raining with the door closed....like I said just pools somewhere and then gushes in when I open the door.
Anyone else experience this or know how to fix? I looked at the weather stripping on the top or the door and it looks intact. 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #441508 14th Jun 2017 3:07pm
nebc100
Luxembourg 2003 Range Rover SE Td6 Monte Carlo Blue
I am new here, but I thought that I read about a technical bulletin regarding this issue.
It was something to do with the door alignment.
I am sure that someone else will come along and correct me though.
Post #441517 14th Jun 2017 4:42pm
horse86
interesting. This just seemed to start happening this year....or at least I started noticing it this year...I rarely have a passenger so it could have been earlier 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #441530 14th Jun 2017 6:19pm
horse86
anyone? 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #441606 15th Jun 2017 4:37pm
sunroof drain blocked?
http://www.fullfatrr.com/forum/topic35621.html ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #441607 15th Jun 2017 4:39pm
horse86
I didn't know there was such a thing. Where would I look for that/a blockage? Would that lead to the water filtering down and pooling in the door somehow? 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #441608 15th Jun 2017 4:55pm
Does this help?
http://www.fullfatrr.com/forum/topic12101.html?highlight=water
Post #441612 15th Jun 2017 6:06pm
horse86
No that talks about the rear door. My issues is the front passenger side (the U.S. passenger side). My whole door speaker gets soaked and the door panel and the scuff plate right where the carpet ends. It's quite a bit of Water that spills out once the door is opened after a rain. 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #441632 15th Jun 2017 8:35pm
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
As Stan said, Check the sunroof drains, you'll find them in the front corner of the sunroof channel. Ou Shocked rs was running down the a pillar. Get underneath the car and you'll find the bungs where the drain tube exits.
Post #441633 15th Jun 2017 8:42pm
horse86
the sunroof drains can only be seen when the roof is open? I've never crawled up there to look. How would these drains catch that much water that it literally splashes down on to the door panel when I open the door after a rain? Would that mean the seal around the sunroof is bad?
Where about does the drain empty under the vehicle? 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #441705 16th Jun 2017 6:25pm
PaulTyrer
Yes you have to have the sunroof open to see the drain holes, there are two at the front and two at the back. If you read the threads above it will explain the location of the holes under the car, they are at the front of the door underneath and behind the sill. The one above the air suspension tank is awkward to see
Post #441784 17th Jun 2017 2:36pm
horse86
Well I opened the rear passenger (US passenger side) and it did the same thing...so must be the sunroof drain holes.....now how the heck to unclog them haha. 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #442031 19th Jun 2017 8:49pm
PaulTyrer
You can use strimmer (weed whacker) nylon cord as its stiff but flexible, I used wd40 with an extension nozzle to blow the tube through, it did work! I guess if you have a low pressure airbrush you could try that, but I think the nylon garden cord would work, but not too much pressure
Post #442034 19th Jun 2017 9:16pm
horse86
so you start on the sun roof end and push it through gingerly? 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #442193 21st Jun 2017 1:31pm
PaulTyrer
Have a read through these threads
http://www.fullfatrr.com/forum/topic33664....oof+drains
There is also mention of A/C Condensate drain.
http://www.fullfatrr.com/forum/topic14068....roof+drain
Post #442218 21st Jun 2017 4:58pm
